3.2 to 3.0 wiring necessary.
Shovert
ky
Since I have check engine light on all the time, Lot of codes, [Running non SHO trans]. I have decided to wire to the 3.0 and repin the computer to suit.
There is 6 wires not sure about.
Pin 39 label sccs gnd. goes to a steering wheel ctrl sw
pin 28 label sccs goes to a steering wheel ctrl sw
Next say goes to cruise ctrl servo. My car has a standalone cruise control.
Pin 51 label scvac
Pin 35 scvnt
pin 11 label sol+
Pin 30 label Clutch pedal position switch. I assume for shut off of cruise control.
I have done read need to hook up the 2 fuel pump wires together since I am running only fuel pump.
I assume no need to hook up these wires.
I am doing a pin swap chart. When get done I can post so useful if someone doing same. Won't post till sure all works. Maurice
what year is the SHO wiring from?
the 3.0 cruise wiring is completely different from the 3.2, because the atx cars used the electronic cruise servo and the mtx cars used the vacuum powered cruise servo.
Shovert
ky
Had to build the wiring harness. I took a 2.3 Ford Mustang one and repinned and added wiring to suit the 3.2. Got it running with this wiring and computer but codes. Got a LOS computer. I seen in the wiring will need to add a MAP sensor that is not a problem. Maurice
Shovert
ky
Finally warmer in KY. Got a M code IRCM. Going to repin for 3.0 this week and we shall see. Maurice
