94SHOgun
just put about 1,300 miles on my 3.2 mtx(106350 miles when completed swap) and the top end started to rattle slightly in the rear head(towards fire wall) the rattle has gooton progreessivly worse and know you can feel it in the pedal and i am back firing out the intake..108570 miles....either i swallowed/bent a valve, valve lash needs to be done becuase i know it was no at 100,000, possible timing jump? need new belt and check timing, the cam sensor is brand new.. (i have a new crank sensor to install). oil has no water or coolant in it but coolant is "muddy" for the second time. i changed it about 2,700 miles ago becuase it was muddy. i am going to open it up on saturday any suggestions on what i am looking for.
Thanx
Thanx
