3.2 and accessories into a MTX
shoZirra
LA, CA
Hi I am an old SHO person and wanted to tray something new for me. I want to put a 3.2 with 3.2 accessories into a 90 MTX. I've done all sorts of SHO stuff but I need help with the motor mounts for this project. I will be using an MTX subframe. Because of the 3.2 accessories I will need to use at least the top end of a 3.2 motor mount, will I need to combine it with the bottom end of a 3.0 motor mount? What would the offset would be required if I sit the 3.2 on the 3.0 subframe?
Thanks
PS I did search this site and found no specifics.
93rev2sev
Hockeytown
Seems like a worthy goal. Are you trying to keep weight towards the rear of the vehicle by utilizing the MTX subframe? I thought the total was about 3 inches. Not sure anyone actually measures it. I think most would just drop the engine on a subframe, support it from above, position the engine and mock something up.
yup, you just need the custom front mount.
