3.0 ATX?? It's a silly question but please confirm
Cward
finder of parts
Big Lake, MN
Okay I'm pretty sure it will but will a 89 3.0 SHO motor bolt up to a 94 ATX trans? I'm figureing yes as the MTX bolts to the 3.2 but just want to be sure. :biggrin:
Ishodu
It will but you will have to change things, pretty much the same things as in a MTX 3.2 swap. You will loose a lot of TQ by doing the BTW.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
There are two bellhousing to oil pan bolts, the locations differ a bit between the 3.0 and 3.2 Also the oil pan is shaped different as the Y pipe takes a slightly different route under each engine.
One of the exhaust manifolds is different, which ties in with the Y pipe being different.
Perry
