St Louis SHO
Rollin' coal
No, Randy, Better yet, let him ride with Brian. Maybe he'll yack at the end of a lap.
..............................I don't think the "fapping" noise is Liberty's car...
:theyareontome:
Whoa, 6500, that's almost the redline! Look at you, flirting with danger!
I bet it also depends on whose driving it.
If there isn't a lot of torque ever put forth on the cams (let's say below 2500 RPMs), then the cams might stay intact. This isn't always true, but if a driver never goes very fast in it, this will prolong it.
It's just physics.
i beg to differ on that just a little bit, considering that im 19 have a 220 hp 7000 rpm reving taurus with a 5 speed which makes for the best combination in my book for the simple fact that on almost a daily bases it sees revs of close to 6500 rmp if not more.
so how would be be that the older crowd would drive their shos any harder then i do, or any of the younger folk if any of the youngins drive like i do that is.
Nope, I was at 150,000K with 50+ bottles of NOS and just decided to weld mine because I had already welded about 500 others and I would look real stupid if mine blew up.
Not all of the cams are bad, They get made and placed in bins, then as they assemble an engine they reach in and grab what ever cam is closest and install it. So there are some"very few" that got all good cams.
E1, just an FYI you say we at camfailure.com.. "We" meaning "you" havent been there all that long and one of the founding members of V8SHO had a car at 300,000 well before you came in. Al,s car had 300000 miles on it in 2002, now that im thinking about it.
What ever the case is. they all should be welded if you want to keep the car. if you wish to gamble then gamble, if you want to drive the car them weld them.
What you say hardly makes sense.Nope, I was at 150,000K with 50+ bottles of NOS and just decided to weld mine because I had already welded about 500 others and I would look real stupid if mine blew up.
Its the Manuf defects with the heating and cooling of dissimilar metals is what cause the slip. NOT BRUTE FORCE.
Well, cold makes metal contract. And different metals contract different (and expand differently) in different temperatures. So, we can say that the sprocket and the cam probably contract and different rates, and we can safely say (based on what you've seen) that the cam shaft shrinks more than the sprocket. So, based on that, then at start or by driving, the torque exerted on the cam will cause the sprocket to slip easier (the frictional force on the sprocket will be smaller). So, what I say is indeed true, and what you say is in part true as well.Colder months always bring more and more camfailures.
Dissimilar metals expand and contract at different rates.Realllllyyyy... then how is the sprocket supposed to slip? Magic? I don't think so.
stephen does make a good point.. we will never know.
But.. based on the new numbers... I will probably lower my percentage to maybe 40%.. with a margin of error of +/- 5%.
I have a SHO sitting in my garage right now which is not welded, has 130k miles on it and is running strong and there are no slip marks on the cams.
Based on that and what other people have said (and these are only people on these forums).. there has to be more. So you have to take that into account.
Anyways... good points. I'm out!
