Entropy
Hates Pinch Bolts
38SHO said:you can get better handling when you switch to a smaller tire if you are already using a tire too wide for your wheel. I like how u say most performance cars run wider tires AND wheels... big point there. You won't see any race car running 275mm wide tires on a 6" wide wheel because it will handle like shit if u could even mount it on there.
find me a picture of a ******** race car that has tires bigger then its wheels and buldges out. You should also check out what the tire manufactuer recromends what size wheel you run a 225 50 16 on.
OK, since I'm in the helping out mood today, I'm going to follow your logic. I looked up the first three cars that came to mind and recorded their #'s
Car: Corvette Z06
Wheel: 18 X 10.5
Tire Width: 295 mm - 11.614 in
Tire is 10.6 % larger than wheel width
Car: Ferarri 550 Maranello
Wheel: 18 X 8.5
Tire Width: 255 mm - 10.039 in
Tire is 18.1 % larger than wheel width
Car: Jaguar XJR
Wheel: 19 X 8.5
Taking the average of these 3 cars, a performance car tire should be in the neighborhood of 15.6 % larger than the wheel size.
Since the SHO has a 6 inch wheel, this corresponds to a 6.93 inch wide tire or 176.17 mm......
Ohh, dude....you should have gotten the 175 X 60 X 16 !!! Those 205's are way too wide for your car!
