2018 Granatolli exhaust cutout install Thread.
VibraSHO
Anchorage, AK
I will be installing the Granatelli exhaust cutouts on my 2018 non-pp today.
06365faa3741eecc70d85d8a92269d33
These are the parts that were sent times 2. I like the switch idea if I could route them to one switch and I’d install this next to the traction control switch.
330266918f77aa2d60b67213ea3af348
I ordered the remote adapter as well, I will hook this to the 2 remaining slots on my garage door opener (home link) if the above method doesn’t work out.
I will look for a spot and update.
7c5c6987223bdf15cfbc8622b7f8c101
Need about 10-11 inches of original pipe size. Good time to delete the cat? I could fit it between the cat and muffler with some modification. Anything before will be cutting into the PPE catted DPs. Thoughts??
VibraSHO
Anchorage, AK
Figured I only need about 8 inches, not the 11 that I thought initially. Going to go between cat and muffler.
VibraSHO
Anchorage, AK
Here is the picture of the cuts. Used a reciprocating saw to make the cuts, angle grinder to clean it up. I cut a bit short to make sure the cutout will fit. 3a193f90d596b4c5be57c7f3d54b25f1
VibraSHO
Anchorage, AK
5892187bc8cfb9f2474580cb6d681630
Driver’s side installed. Used a lightweight rubber mallet. Started with the muffler side, pushed in as close to the muffler as possible. Then I pushed the muffler and cat apart and slid it on. I used the rubber mallet on the ****** that is pictured to lightly tap it into place.
C218a429112b11984b204ab911d7acac
There is about an eighth inch gap as shown, I cut too short. This gap is on each side, however, the clamp will cover this up nicely.
0e97f7ddf5cfd6d18d83dd91087516ef
Here is the passenger side cat. You can see how I had to use the grinder to clean up (not finished yet). I needed to grind at a slight angle to make a funnel shaped so that the pieces fit together properly. I had to do this on both the cat and muffler side.
VibraSHO
Anchorage, AK
Note: don’t connect one before the other. Now I can’t get the passenger side in because the drivers side won’t come out. Connect both exhaust sides first, then work the cat side together.
Stupid mistake on my part.
VibraSHO
Anchorage, AK
62a9ed7f09785fd35c97003e7a5421b5
So I ended up dropping the cat. I recommend this as it takes 5 minutes and will make the instal easier. After the cuts of course it it actually drops down. It just swings down once you disconnect from the resonators.
2ecdfe26379985519502739b547b15e5
Here is a picture of both attached to the muffler side.
VibraSHO
Anchorage, AK
Pretty easy from the last post to complete hookup. Here are the pics of it installed minus the door and wiring. I’ll finish that tomorrow.
6b84663071578b7fc85b6629aaf06336
F10daddd46771752c1a48ff12949754b
76FoMoCo
Nampa, ID
Looking great. Not much for power gains but fun. Why not put them facing the other way?
Seems like you might have them mixed up side to side and 180*?
CCXVI
Surprisingly it did make a little low end bump. One of the clay hills I used to drive up regularly I noticed it had less trouble with them open.
As fun as the dumps were I realized I had them open more often than not, and that's how I went with the driver door exit. I'm really thinking about another SHO in a bit and going with the vacuum actuated dumps this time.
VibraSHO
Anchorage, AK
I figured it would be better for airflow, it has a straight path from the cat to the muffler. If I swapped them, it thought it may dump the majority of exhaust into the muffler, instead of into the cutout. My thought process was path of least resistance. I may have over thought that though.
VibraSHO
Anchorage, AK
I could see myself driving with them open the majority of the time. Certainly been a fun mod to install and mess with. I’ll be back at it today with the wiring.
CCXVI
Tons of drone with it exiting under the car though. Great at anything except cruising. Idle/parking lots it sounds great, and flat out it's not really noticable, but on the highway or something it's pretty bad obviously.
VibraSHO
Anchorage, AK
212ac163fa1933dc37b27939021307ba
B0d628a51bb224268f1f91f14817aad2
D1d07a34c9aeff1f2301bd16d03b0963
Alright here I’m installing the gaskets to the exhaust ******. I ran the bolts front to rear.
2b5b1be95219a539b20fb867169b0f23
So the bolts screw into the “3-bolt exhaust ******” (pictured). The supplied nuts were not used. If I put the nuts on as well the clamp with tip would not fit.
1223d3c0ecca0edd9fffd075a3af1585
This is the clamp and tip I’m referring to.
I ended up using the lock washer at the beginning of the bolt between the bolt face and ******. Used lock-tight on all three bolts to be safe.
D87729733b2c1139c8aaff85daa2ccf8
Drivers side complete.
38e1f7691924a516559bdd44a7def284
Both sides in. Wiring is tricky for the passenger side. I’m working on wiring through the heat shield to connect the two on the drivers side.
VibraSHO
Anchorage, AK
I took it out last night prior to installing the remainder. The drone is wicked when I was cruising. I can’t even imagine how it would be on the highway at full open. I agree, it sounds really good at an idle.
shootinirons
