2013 Climate Control Issues
msa768
2013 Taurus SHO
Arlington, TX
I have a stock 2013 SHO that started having an issue with the climate control panel yesterday. Here is the issue:
While driving home from work, with the A/C blowing cold, the climate controls shut off. I press the climate control power button and the A/C comes back on. This issue repeated over 12 times on my commute home. Any ideas what could be causing the control to power off? I'm in North Texas and temps are above 100 degrees and I need my A/C! Any suggestions would be greatly appreciated, thanks!
SHOrod
Torrie Tuned
Cedar Rapids, IA
Have you replaced the battery in your 2013 yet? If not, you're getting about to the point where the battery is likely to be on its last legs. So many odd electrical issues in modern cars can be traced to weak batteries that, if it were my car, I'd start there since it won't really be wasted money. If that doesn't take care of the issue, then get in to deeper diagnostics.
I haven't stumbled across a self-diagnostics mode for the HVAC in the models with touchscreen navigation, but I haven't looked yet for the non-touchscreen. Which version does your SHO have? Was non-touchscreen even an option in 2013?
-Rod
msa768
2013 Taurus SHO
Arlington, TX
I replaced the battery 2 weeks ago with one from Interstate. My SHO does have the touchscreen navigation, any ideas or help would be appreciated. Thanks.
sperold
Last to Know
Any chance your freon-charge is a bit low. I think the system has a shut down (or will not even begin to work) if the freon-charge is low.
You could try to see if any codes are set in the HVAC module. You'd need an OBD reader that can access the MS-CAN bus, and an app like Forscan to display data from the bus/module. Here are codes from a 2010, 2013 probably similar:
DTC Description
B1081:00 Left Temperature Damper Motor: No Sub Type Information
B1081:11 Left Temperature Damper Motor: Circuit Short to Ground
B1081:12 Left Temperature Damper Motor: Circuit Short to Battery
B1082:00 Right Temperature Damper Motor: No Sub Type Information
B1082:11 Right Temperature Damper Motor: Circuit Short to Ground
B1082:12 Right Temperature Damper Motor: Circuit Short to Battery
B1083:00 Recirculation Damper Motor: No Sub Type Information
B1083:11 Recirculation Damper Motor: Circuit Short to Ground
B1083:12 Recirculation Damper Motor: Circuit Short to Battery
B1086:00 Air Distribution Damper Motor: No Sub Type Information
B1086:11 Air Distribution Damper Motor: Circuit Short to Ground
B1086:12 Air Distribution Damper Motor: Circuit Short to Battery
B10AF:11 Blower Fan Relay: Circuit Short to Ground
B10AF:12 Blower Fan Relay: Circuit Short to Battery
B10AF:13 Blower Fan Relay: Circuit Open
B10B9:12 Blower Control: Circuit Short to Battery
B10B9:14 Blower Control: Circuit Short to Ground or Open
B11E5:11 Left HVAC Damper Position Sensor: Circuit Short to Ground
B11E5:15 Left HVAC Damper Position Sensor: Circuit Short to Battery or Open
B11E6:11 Right HVAC Damper Position Sensor: Circuit Short to Ground
B11E6:15 Right HVAC Damper Position Sensor: Circuit Short to Battery or Open
B11E7:11 Air Distribution Damper Position Sensor: Circuit Short to Ground
B11E7:15 Air Distribution Damper Position Sensor: Circuit Short to Battery or Open
B1A61:11 Cabin Temperature Sensor: Circuit Short to Ground
B1A61:15 Cabin Temperature Sensor: Circuit Short to Battery or Open
B1A63:11 Right Solar Sensor: Circuit Short to Ground
B1A63:15 Right Solar Sensor: Circuit Short to Battery or Open
B1A64:11 Left Solar Sensor: Circuit Short to Ground
B1A64:15 Left Solar Sensor: Circuit Short to Battery or Open
B1A68:11 Ambient Temperature Sensor: Circuit Short to Ground
B1A68:15 Ambient Temperature Sensor: Circuit Short to Battery or Open
B1B71:11 Evaporator Temperature Sensor: Circuit Short to Ground
B1B71:15 Evaporator Temperature Sensor: Circuit Short to Battery or Open
C1B14:11 Sensor Supply Voltage A: Circuit Short to Ground
C1B14:12 Sensor Supply Voltage A: Circuit Short to Battery
U0140:00 Lost Communication With Body Control Module: No Sub Type Information
U0155:00 Lost Communication With Instrument Panel Cluster (IPC) Module: No Sub Type Information
U0163:00 Lost Communication With Navigation Control Module: No Sub Type Information
U0256:00 Lost Communication With Front Controls Interface Module (FCIM) "A": No Sub Type Information
U0422:68 Invalid Data Received From Body Control Module: Event Information
U0423:68 Invalid Data Received From Instrument Panel Cluster Control Module: Event Information
U0464:68 Invalid Data Received From Navigation Control Module: Event Information
U0557:68 Invalid Data Received From FCIM "A": Event Information
U3000:41 Control Module: General Checksum Failure
U3003:16 Battery Voltage: Circuit Voltage Below Threshold
U3003:17 Battery Voltage: Circuit Voltage Above Threshold
NOTE: Some PCM DTCs may inhibit A/C operation. If any PCM DTCs are retrieved, diagnose those first. Refer to the PCM DTC Chart.
P0532 A/C Pressure Refrigerant Sensor A Circuit Low
P0533 A/C Refrigerant Pressure Sensor A Circuit High
P0645 Air Conditioning Clutch Relay (A/CCR) Control Circuit
P1464 A/C Demand Out Of Self Test Range
