2011 SHO cooling fans constantly running
colingraham89
Dallas
Even after cold crank they’ll start up shortly. All the temp gauges on dash look okay, no check engine light. I know this was common issue and could be number of things. Was hoping I could be lead in the direction of where to start and test. Trying to become my own D.I.Y. amateur mechanic. Have owned this car for 130k miles myself. Very few issues. Thanks all for letting me in the forum!
Honz24
It could be that you have the vents set to defrost. When the vents are set to defrost it turns on the air conditioning to remove moisture from the air and the fan will run.
Satchmoz
