1996 sho front engine mount
Pablo sho
I replaced my engine mount less than a year ago and my engine about came out of the hood today. Ok maybe I'm exaggerating a little but this thing doesn't seem to have a interlock. What a pos! Any recommendations to where I can get one that will hold? I dont drive hard....dont generally take off fast...occasionally my put the petal down when I'm already moving.
gamefanatic
Barstow, CA
What mount did you use? Maybe just defective.
I've used:
Westar EM-2934 (Amazon)
SKP SKM2934 (RockAuto)
So far so good. I prefer the SKP, as the Westar moves a bit more and is slower to return. My goal is to make solid mount out of my previous skeleton OEM mount.
Pablo sho
Thank you for the quick reply. I cant remember the brand.
I think I got it from AM or Al parts. Something like that I will see if I can find it in my emails. The top mounting holes were to narrow and I had to elongate them to make them fit.
I found a oem one that looks the same but it says it's for a 3.0 sable?
Pablo sho
I see rockauto list a solid mount. They have 2 left.
gamefanatic
Barstow, CA
Not sure of the duratec mounts, but the vulcan I would not think is the same. Likely different distances.
Solid mount sounds good. Looks like that would be the one to go for if they still have them in stock. Seems like that part is running out on many sites.
Pablo sho
Oreilley lists one for $30. Limited lifetime warranty. Going to check it out tomorrow. Hopefully I can get one tomorrow. I'm really tempted to just make a solid mount. Rockauto had 2 but no picture.
gamefanatic
Barstow, CA
Limited lifetime is better. The mount you take out can be made into a solid if you are so inclined to do it yourself.
99sho-time
I used a SKP and it failed horribly in like 2 months been using an anchor from advanced auto parts for over a year.
GEN 3 SHO FAN
Canada
Don't forget that with a solid mount, you will feel more vibrations coming from engine (at idle mostly). I replaced one on my Sable (3.8L) and the difference was clearly perceptible.
Pablo sho
I ordered one from O'Reilly. If it breaks it's under warranty as long as they're still available and easy to exchange.
I pulled it out just now. Seems the nut came loose (no locktite) causing premature failure.
gamefanatic
Barstow, CA
Agree, anything more solid will transfer vibrations through the system more. Its not bad, but can cause unsatisfying if you just want a date night.
The converse is you get more feedback to the road, and to possible issues.
That's why I have one SHO as much a stock ride as possible for the daily ride, and one like its on rails stiff for the sporty days. Which still occur more times than not... :biggrin:
GEN 3 SHO FAN
Canada
I like your plan ! :D You're a better GEN 3 SHO FAN than me...
Now, where can I find a second one...
Thanks for the photo Pablo. I have some noise (clunk) from engine bay and wondering if one isn't going away...
Daniel Aiken
The only real fix for this issue is finding an NOS part. The front mount is F7DZ-6038-BA.
I’ve found most all the aftermarket mounts are crap. Many are 3.0 mounts listed to fit 3.4. Some fit, some not so much.
I try my best to only use genuine Ford parts in my SHO and am always buying parts as I find them.
Now if anyone knows where some rear SARC struts may be laying around.......
Pablo sho
Well the new one looks like crap. It's in a anchor box but the parts person said it's not...they just come in those boxes. A ford one would be nice but that ain't happening today.
Pablo sho
Well crap again! I think I cross threaded one of the bolts. That's going to be fun to fix. Only goes in a turn or two. Off to town to buy a tap.
GEN 3 SHO FAN
Canada
Reading your post and searching for this part, I just recall that someone had made renforced motor mount Gen 1 and 2 SHO. IIRC, it was someone in the team of SHO Source (or near of).
I rode this long time ago, not sure if it's still doable or reliable for long term...
I found it. Sadly it's for the rear one. Maybe we can repair front ones too ? They do a renforced version of the front manual 3.0L SHO.
http://www.shosource.com/catalog/product_info.php?products_id=625
Front for MTX 3.0L SHO
http://www.shosource.com/catalog/product_info.php?products_id=38
SHO forum solution for the 2.
http://www.v8sho.com/SHO/MotorMounts.htm
Pablo sho
I got the new one in. I didn't screw up the threads that bad. I was able to get it started straight after removing the mount.
I then reamed the holes in the mounted and was able to get the bolts in.
thatSHOguy101
