1992 airbag light coming on.
Bryan
What do you get when a deer & SHO cross at 45mph?
Morgantown PA
So the airbag light on my 1992 sho has been blinking at me a lot. Seems like the code is 35. Any ideas what this is related to? And what the possible fix is?
DTC 35: PASSENGER SIDE AIR BAG MODULE LOW RESISTANCE OR SHORTED
Possible Causes
Low resistance across Pins 8 and 9 can be caused by:
(1) A poorly mated passenger air bag harness connector not pushing the shorting bars back into their fully-retracted positions.
(2) A damaged shorting bar may short Circuits 614 (GY/O) and 616 (PK/BK) together.
(3) A short across the passenger air bag terminals within the passenger side air bag module. DO NOT attempt a direct resistance measurement of the passenger side air bag module. Follow the diagnostic procedures to determine if the passenger air bag resistance is lower than normal.
(4) A short in the wiring harness between Circuits 614 (GY/O) and 616 (PK/BK).
(courtesy of Rockledge from 2006)
Bryan
Morgantown PA
So its a problem with the airbag itself? Or in the front bumper?
