1991 SHO sitting for 8 years
Mikey
Dallas, Pa
I use large pliers while slightly compressing the rear caliper pistons with a c clamp to get them loosened up. Dont tear the rubber..lil twist..lil sqeeze..repeat.
Mikey
Dallas, Pa
Can't you try to catch it in gear ? Or no brakes yet? Keep at it you'll love it
ISHOU
Centennial, CO
Glad I'm not the only one who's changed a starter only to find a bad battery terminal after the fact. After a few bad rebuilds, your mind just takes you in that direction.
papichulo
NY
Centerforce stage 2 dual friction clutch still in plastic with HD orange throw out bearing for sale. I'm on Long Island ny.
300 bucks.
Sonodeep
I had this same problem and I had to replace my fuel pump and filter. Old gas can ruin the pump if it sits for a long time.
RjS
Nebraska city
I just bought a 91 that's been sitting for a long time as well any tips on getting old gas out or just siphon?
Plan on dropping the tank? I'd think you at the very least siphon out the old gas, put in HEET or similar "water suspending" additive, then fill up with fresh fuel. Replace the fuel filter also. Then attempt to start the engine. Fuel injectors may be gummed up ...
RjS
Nebraska city
I'm going to try at all costs not to drop the tank but if I change the filter I'll have to right?
Sonodeep
I would drop the tank and drain it, then replace the fuel pump which is likely gummed up. The pump should have a sock filter on it. There is also a filter along the side and underneath the car, in-line with the fuel line that should be changed.
Devin
3.Slow
Pacific Northwest
Good luck. On the extended tanks, at least, there is a defeat feature for siphons. I wasn't able to snake a silicone hose around it, and had to drive my fuel out.
