fordsho8991
If I have my fogs on long enough (about half hour or so), my headlights will start flickering on and off until I shut the fogs off. I'm using the stock wattage h3 bulbs (55 watt). I originally had put the blazers in and it did the same thing. Thinking it might have been them, I went and got the oem fogs and bulbs, only to have the same issue. I already burned up one headlamp relay in the turn signal/wiper/high beam stalk, and I dont want to do it again. I just can't figure out why it's doing this with all stock fog components. I did put nokya arctic white 80/100 watt headlight bulbs in, could this be a possibility? They work fine without the fogs on and I have had no issues with them otherwise. Thanks for any info.
-Ken
-Ken
