16G Turbo sho Sees BOOST!!!
TT SHO PROJECT
OHIO
Just took my 16g turbo sho out on a test run... low speed boost run... and i saw 3-4psi boost max around 3-4krpms... not Too bad since the engine was cold still... but she works!! About damn time too.
-Bob
P.s. i should have pictures in a couple days.. i did finaly get ahold of my friend with the digi cam.. so i will have pictures asap!
TT SHO PROJECT
OHIO
SuperchargedSHOguy said:
Congrats Bob! :thumb:
Yeah thanks man... i dunno if this counts as my first turbo kit? or my 2nd? hehe well this is my first Working kit we will just say that :p cant wait to get to drive her some more and feel the power and also see if my injectors can keep up or not. didnt hear any lean knock at 4psi so we will have to see how 8psi goes.
TT SHO PROJECT
OHIO
Just checked out the car for a post first Run inspection... everythings A Ok minus the discharge elbow right off the turbo wasnt tourqed down lol.. probably was leaking boost... and the oil level looks one qt low.... i put in 5 or should i of put in 6?
-Bob
5speedSHO
Nebraska
i would have put in .5qt extra because the turbo lines and turbo will hold a decent amount over stock
somedude_001
Western NY
my car has always taken 5.5 qt to fill it after a oil change is the 3.0 different than the 3.2? the computer at works says they both take 5.0 but with 5 qt in my car it is not in the hash marks... definately add oil if its low.
TT SHO PROJECT
OHIO
yeah everywhere i look it says 5qt's but i was atleast .5 low so i just slapped a 6th qt in it and its within the marks now.
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
definitly check it once you start it and let everything settle because the extra 'charger and plumbing will require additional oil.
