120K complete! 3-days and bruised hands/ego
Deaks2
Montreal, QC, Canada
Hi all. Up at 200,056 km (~120k miles) so decided it was time for a 60k. Took 3-days on and off but its done :p
Started Friday morning by cleaning out the garage and fitting this beast of a car in there, this thing takes up more room than a minivan! Friday I stripped her down to the timing belt cover and crank pulley, decided that the dust from the wheel-well liner was telling me to call it a day.
Saturday things got interesting, broke two things but fixed them, middle timing belt cover where the plastic loops around a metal braket on the firewall side of the engine (easily fixed with epoxy) and the metal window attacked to the crank sprocket which the CPS slides around, bend it back with subtle pressure in a vise.
Sunday was spent putter her back together, althought my replacement Alternator/AC belt is way to tight, tensioner does not even fit, have to replace that this week. Getting the bubbles out of the cooling system got the temp guage as high as have ever seen it, well past the N in Normal. Managed to make her stall a couple of times, but the ECU leanred things pretty quick.
Overall a good experience, glad I had an experienced mechanic with all the proper tools and 10 years of Mazada-dealership experience to help out, he was amazed how the timing marks stayed aligned even after the tensioner was put in place, apparently the 2.5 and 3.0 litre Duratechs don't play so nice, one cam skips a sprocket tooth once pressure is reapplied. In the end I changed the timing belt, crank position sensor, crank seal, water pump, accessory drive belts and thermostat. Standard fluid replacement as well (oil and coolant).
Now at least I have eliminated the CPS as a source of Check Engine lights, and with the O2 sensors having been replaced last summer I think its about time I stopped being lazy and read the codes :p
Note: Valve-tapet adjustment was not necessary this time around, all the shims were in good shape.
BlackOnBlackATX
Dutchess County, NY
HERE HERE!! You are an inspiration to the rest of us! beer beer
I plan on doing my 120k this spring! Hope it goes as well as yours did! (or better wink )
And I second the motion about how big the SHO is, it's quite deceiving at first! But I like big cars thumbs_u
I hope you accurately restored the "metal window" on the crank pulley. The gap from that window to the crankshaft position sensor is only .03". Did you measure the CPS gap on all three vanes of the sensor ring? That would have been an insurance policy that you wouldn't have future CPS problems. Overall, good job on completing the process yourself.
Deaks2
I live in Vaudreuil, a suburb to the west of the island of Montreal. As for the metal vane/window for the CPS, I used a feeler guage to mesaure the distance for a few rotations, I managed exactly 0.8 mm all around.
