114?
oh_SHO
Ohio
I got a 114, IAT out of range or something like that. What does this effect? The only thing that it does is the idle bounces around when its hot and starts hard. Usually have to floor it. I was thinking that problem is due to a sticky/bad IAC. Going out in the freakin' cold to clean it now...
rangerj
Brunswick, Ohio
oh SHO,
With the air ambient temperature below 50 degrees F, the IAT is going to be out of range. Its "range" stops at 50 degrees F (simplified).
You can pretty much ignor this code until the weather warms up. As for your other problems, I think you are on the right track.
Think, if it isn't electronic, ie no other codes, then it has to be mechanical! rangerj
oh_SHO
Ohio
Sweet, I didn't want to replace it. I am getting the car ready to sell to a local here. Thanks for the info. The 92 ain't owning me; I'm owning it. hahaha
oh_SHO
Ohio
Um, what should I use to clean the IAC? Aren't you not supposed to use Carb cleaner?
