02 sensor
hoofbeat
in.
Just had the service eng. lite come on,plug in my code reader tells me cde po130 which means heated 02 sensorcircuit malfuntion bank 1 sensor 1.how fix?
I will venture to say that if the wiring looks OK, the O2 sensor indicated needs to be replaced. There are 4 sensors in all, 2 for pre-catalytic converter (CC), 2 for post-CC. Assuming you have a SHO, bank 1 sensor 1 would be the pre-CC sensor on the firewall side of the engine.
SHOrod
Torrie Tuned
Cedar Rapids, IA
If you have access to a scan tool with datastream mode (or the free Torque app and OBD-II dongle) you can monitor the B1S1 sensor voltage real time to see if it's slow to respond, not changing, or railed to either 0.1V or 0.9V which could help you determine if it's likely a sensor, vacuum leak, or wiring issue respectively.
-Rod
hoofbeat
in.
Thanks for the quick replys. Will check it out today.By the way i have a 2010 SHO with pp with 16,000 miles on it and other then peeling tail lites this is the 1st problem i,ve had.
hoofbeat
in.
:thankyou:Car is repaired. Took the car to the ford dealer were i bought the car(also bought a 2012 prem gt. there) would not take the info. i had or the info from the guys on this web site. Wanted to charge me $95.00 per hr.plus $170.00 for the sensor. Had a friend that had a multi stage code reader and verified the bad sensor.Searched the internet and found this company oemparts123.com had Motorcraft parts for sale .bought the sensor for $120.00 including shipping(2 day priority ship).The friend charged me $60.00 total for testing and labor.The web site i mentioned i found out was for Don Wood Ford in Athens, Oh. Would recommend them if you need oem parts.
