recovery tank/degasser tank
ThatShoGuy
michigan
anyone know if there is a difference on the tanks.
autozone.com list one for a 12valve motor and a 24valve motor.
nothing for the 32valve sho motor.
my question is are they all the same?
they only one they say is available
is the 12valve tank. are they all the same?
The 12v one only has one small hose ****** and it is on the back side of the tank.
ThatShoGuy
michigan
I got an oem one from the dealer for about 45 bucks. With cap. The 24valve is the same tank.
thats not to bad of a price after shipping that's about what ill pay autozone!
so i assume that wont work!
only reason i wanna replace it is because i have found the cap popped off! and it leaks coolant around the cap.. 1 thing tho i have 3 diff caps 2 oem's and 1 replacement.The replacement can be put as tight as i can make it, doesn't have that click deal the the oem ones. that one even seeps coolant when made very tight.
so that's why i figured invest into a new tank. i did buy a new cap today. along with the much need replacement rad drain plug! hope both fix my little issues?
any opinions
No the Vulcan tank twill not work. Once you have stripped the threads on the tank, which you cannot tell from looking at it, you will not get the cap to seal again. The V8 does not work well with no pressure. It will overheat at slow speeds such as in town.
ThatShoGuy
michigan
no over heating issues and as i know of i didnt tighten it to much
also new cap seems to be doing good, maybe it was just the seal around the old caps! guess i just have to wait and see..
thanks for input
Porkchop
The Black Sheep
Virginia
You can also get tanks off of Ebay if need be for a few bucks cheaper, thats what I had to do... no problems in a few years!
crystizel
