anyone know were to get or what size the spindle pinch bolt is??
ultimatesho
Fort Bragg, NC
called every single parts store in Glasgow and Bowling Green and noone has them or can get em.......advance shows em in their system but cant get em
the ford dealership said they can get em but itll b monday before they can have one in
anyone no were to get one FAST or what size and if any grade 8 bolt will hold it???????
snapped it off in the spindle and i tried drillin with titanium bits just to snap and dull every single one :cry: .......so im just cuttin off the old one and puttin on a pretty shiny bran new one
ultimatesho
Fort Bragg, NC
If you are talking the rear I just drill out the hole and use a 7/16" bolt and nut.
bolt snapped and ive used titanium and cobalt bits and tried to slow drill it just to dull and snap about every single one of em
im just gonna cut off the spindle and put on a JY one
baySHO_510
**** It broke!!
Manteca & Oakland Ca.
I cant remember the exact size but I took my old one that was all bent and replaced it with a grade 8 from Orchard (Hardware store). I did however spend like $18 at Ford on a special order and replaced them later with brand new OEM bolts. THEN after all that I saw the same exact bolts at AutoZone in the HELP! section where they usually have all the hard to find parts. I hope this helps...
Storm-Chaser
Shit Louis
Front Strut Pinch Bolt (M14 x 2.0 x 65mm)
Rear Strut Pinch Bolt (M12 x 1.75 x 57mm)
That is the diameter of the threaded portion of the bolt, the thread pitch of the threads (ie. distance between threads), and the length of the bolt.
Monroe sells a "kit", which is nothing more than the pinch bolt - AK52 and AK50 for the front and rear struts, respectively.
really? 12x1.75? I thought they were bigger than that... huh. :shrug: the more you know!
:burnout:
Storm-Chaser
Shit Louis
You got assraped. The dealer list for the each is $3.75 and $3.88 each.
The Monroe "kits" were $4.01 and $2.52 each (but that was some time ago).
:burnout:
What I do with the rear is to drill them out and use a 7/16" diameter bolt and nut. No problems ever removing them again.
