92 mtx vs. 95 lt1
rocket455
Fairfield, Ca
i have a guy running his mouth on another forum im in about how my car is a slow piece of crap. i just wanted to see what you all think the outcome would be.
i have a 92'mtx
my mods are listed in my sig
he has a 95' camaro with an auto and shift kit, headers, lame tune, intake and exhaust.
what do you think the outcome would be?
Ultymte
Between the earth & sky
I recently ran a friend of mine that has a 95 SS Impala with an LT1 (shift kit, 3.73 gears, and chip) in my bone stock 94 MTX. I was spinning from jump, so he got me out of the hole. I easily pulled on him once I hit third gear. My bumper was at his front door - and pulling - when we had to shut it down. I think from a roll I could have taken him. Now a Camaro is lighter than and SS Impala so your results will probably differ. It shouldnt be a blowout even if you loose. His car was built for speed and yours was built for groceries, so you have something to fall back on :naughty:
38SHO
#1 Oil Abuser
North Palm Beach
that camaro is gonna yank you
lt1 in a camaro has a lot more power then a lt1 in an impala.......
a stock lt1 will get you.... one with gears will eat you alive.....
here is a stock lt1 camaro vs SHO... albeit its the faster 6 speed model... but a modded auto would have no problem pulling a sstock 6 speed....... about 15 secodns into the video begins lt1 **********
LT1's are like 260-305hp depending on year
Huntervf
Bored now
Back in Michigan ... again.
as a mater of fact yes this is at the track, theres a grudge match thats being set up at famoso
Moved to the 1/4 forum :cool:
LT1 'maro, auto... if it's marginally healthy he'll take you, though being an auto he'll be surprised how close you keep it provided you can cut a good launch.
My prediction: He'll pull a car or two by half track, you'll stop the pull at that point and with your mods you start reeling him back on the other end. If he makes even the slightest mistake you may get him by the 1/4, but that's pretty much your only shot. Now if you were going for a 1/2 mile.... :evilgrin:
SHOspazz92
Banned
Triad Area, North Carolina.
I am going to go out on a Limb here and disagree. If it were a 6MT I would give him a better chance for the sake of Driver error. However, The fact that it's a Auto with mods those those engines respond to well and at a sticky track (I know FAMOSO, It's a pretty decent track) I think he's going to get walked. That Camaro should have no trouble trapping at about 100 or so, If that Camaro get's a good Launch (I don't see why it wouldnt) ... Say a 2.0 or better (Assuming he's running street tires) that thing will be in the 13's all day long.
A Highway run might be a little different, But unfortunently for the SHO - Were talking 1/4.
-Sam
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
My dad had a Impy SS with the LT1 in it. Had UDP's and a hypertech chip IIRC. Off the line is where your big problem will be. They have great traction down low. I always seemed to be catching up to him, after his launches, but even tho he has the few extra HP, I beleieve they're heavier too... I wouldn't worry too much... just practice your launches.. :)
Oh.. and after that he bought a 96 Cobra... to make sure I couldn't catch him again.. lol :(
38SHO
#1 Oil Abuser
North Palm Beach
i think impala's get off the line slow, in fact I know they do... my brother had one, everyone in the impala club had problems leaving the gates....
my brother had I/H/E on his...... after he putin a properly working LSD, and 3:73 gears, his 1/4 mile time dropped 1.5 seconds to a 13.8....
a pretty much stock Impala is slow... start modding them decently, or with the right mods, and it will eat a N/A SHO for breakfast........ LT1's don't play
AREA 91
Area 91
My family has 3 Impala's.
Mine is a 1967 2 door coupe, 327/TH350/3:73 10 bolt
Best ET 14.84
4200lbs
Dad's 1996 Dark Cherry SS, PCM 4 less tuning, Headers, cat back, CAI, frame connectors, STB, UDP's, 3:73 10 bolt
Best ET 14.???
4380lbs
Brother's 1994 Black SS, PCM 4 less tuning, headers, cat back, high stall converter, SSRI cold air intake, air foil, 3:73 10 bolt
Best ET 14.2
4380lbs
Now that's Ton's of fun right there!
AREA 91
Area 91
Best ET 14.84
4200lbs
Best ET 14.???
4380lbs
Best ET 14.2
4380lbs
Now that's 13000lbs of fun right there!:p
You will loose at the strip.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
The more I think about the post, "they are bad off the line"... I think you must be talking vs all RWD cars... that "bad" vs a FWD means u need a perfect launch.. :) Otherwise u have issues. It was funny to mess with him when the snow started falling. Somehow those 285's were pretty crappy all of a sudden. :) Car drove sideways from stoplights.
zblackbeast
SHOtarded
Omaha, NE
i beat a TA LT1 6MT to 80...... from 20..... he had a slipping clutch kinda.... You have alot of good mods and unless you can get a good launch off.. you wont beat him.. but youll have a higher trap speed tho.. if you did the 1/2 mile you would be RUNNING past him.
Brett
SHOs before HOs
Minnesnowta
Theres a couple guys running low 14's on 3.2's and lesser bolt ons. Depends on how good a driver are you, and how long you'd like your transmission to last.
Find a used zex kit on egay or craigslist, and be done with it. :sun:
If you had a bottle it'd come down to drivers IMO.
FishMcD83
SHOGTP1
nebraska
I have a bone stock 97 Z28 Camaro LT1, this was the last year of the LT1 and stock rating it has 295 horse and 330 lbs of torque. I have owned MTX and ATX SHO's and neither one will hold a prayer against my Camaro. The only way it will be close is if you run him from a roll. Sorry, but good luck. I actually just bought a SHO for a winter car, so I am back.... LoL.
