ThatShoGuy
I have a tick that happens when the engine is cold and goes away when warm. It is an exhaust manifold leak.
One way for you to find out is to unplug the EGR vacuum line this will stop the heat soak caused by the EGR gasses and the associated thermal expansion. May be too late with the stripped out threads though.
well i cleaned the holes out they were filled with junk.
grabbed some longer bolts and retreaded it.....
i installed the rear 4 new plugs and resealed the cam cover and check the cams all is good..
what the heck could it be??? im goin crazy..
