Brake light on dash acting funny......
yzstud
< my kawi
Minnesnowta
so, when my parking lamps and my head lights are off the brake light is lit up red on the dash
if i were to turn the headlights on low beam, the light still stays lit
but, when i turn on the hi-beams the light goes off. Anybody know why this would happen?
brake fluid is full and the brake switch is operating correctly, so what does this little funky electrical issue mean? :nut:
Kens1992mtxSHO
The Commonwealth
X2.
Had this same stupid problem, turned out the rubber stopper had melted a little causing the light to come on when I went over a bump.
yzstud
< my kawi
Minnesnowta
is the brake light on the dash in any way tied into the multi-function lever?
it(brake light indicator on dash) comes on when headlights are on low beam, but then the light turns off when i flip it on hi beams
this is really starting to tick me off
any ideas?
projectSHO89
SHOless In St L
St. Louis, MO
any ideas?
There are only two things that are supposed to turn on the BRAKE warning lamp: Low fluid (from the float switch) and the emergency brake sensor switch.
The signal doesn't go through (or anywhere near) the MFS.
Sounds more like either someone hacked up the wiring and got it wrong or there's a short between two adjacent circuits in the cluster.
Do the head and running lamps come on when you set your e-brake?
Steve
yzstud
< my kawi
Minnesnowta
Steve
fluid level is at the max line, e-brake switch is good(swapped a known good one in)
what wiring could have been hacked up?
head lamps nor running lamps come on when i set the e-brake?
anymore ideas?
