well i was fixin some wires and now
ThatShoGuy
michigan
well i was fixin some wires i found that were a little melted pulled them apart and fixed this one that was cut and twisted together now.. every time i turn the key on i pop the ecm fuse under the hood 30amp.....
i didnt cross any wiring.. what could be the deal???
stephen newberg
Ladysmith, BC, Canada
When moving things around it is possible another spot that had melted insulation is now touching somewhere and is grounded. Time to sheathe the entire harness, I would guess. If that does not do it, then something either is crossed in your reconnects or two are melted together and touching.
pax, smn
ThatShoGuy
michigan
pax, smn
yea idk what the deal is all i know if it was the power block thing with 4 wires by the pcm ,2 of the wires go to the pcm power.. i fixed and re tapped the rear wiring... now i got it down to if i un hook the 2 red wires think its called the constant control relay module and it wont pop the fuse. sounds like im bout to have fun
ThatShoGuy
michigan
anyone have some kind of layout of how the engine harness is ran.. like were all the wires go
hey shoz123 got anything to tell me lol thanks
ThatShoGuy
michigan
well i been up lookin thru the ford tech cd/manual and looking at the wiring schematic and from what i fixed there is no way i hooked up a ground wire to my wires so only thing i can figure is i cause a short somewhere i got an idea were to somewhat start to work.. its somewhere between the ccrm to the pcm or fuel injectors or puge valve for the evap is part of this..
so i think once i figure out this most of my intermittent codes will be gone thanks for any help givin
good thing i was only 2 questions form getting my auto certification in electrical when i was in auto school. just never went back for it.
ThatShoGuy
michigan
what caused the wires to melt? engine heat or the wire itself get hot.
i wanna say heat.. because the casing of the wires were only melted to them self. didnt see any open wires besides the one that went to the evap purg valve and it was cut in half and twisted and tapped up??? wasnt me.....
anyways i went to my wiring some and found that when i unhooked the fuel injectors RED wiring and away went the short.. to bad the car wont run without it...
ThatShoGuy
michigan
well i figured it out one of the wires for the fuel injector was shorted out on the intake.... go figure car runs thanks for any input guys.. tell the truth it runs some what better:rofl:
shobroooo
