Also, any cam information would be appreciated. Especially if someone knew the factory LSA (if this is possible on a DOHC engine).
Camshaft data:
http://www.shonutperformance.com/SHONUTCams.htm
I am not sure SHOnut quotes LSA numbers there. There is another list member here who has looked at LSA on the +40 cams specifically, I suppose he may pipe up at some point. The factory MTX overlap is tiny, I recall that much (5 degrees or less).
Will you be doing any engine modeling using software? If so, would appreciate it if you could run some numbers for me (my application is max reasonable rpm ; - ).
SHO amo, know ye not of Teflon coated differentials?
zak
