I just picked up a 1994 3.2 ATX, and I'm going to be completely rebuilding it. I'm going to keep it NA, but I want to max out the potential. I'm planning on doing the following things inside the engine:
1. Off-center grinding the crank to lengthen the stroke
2. Zero-decking (custom con-rods?) for ideal quench
3. DCR at 8.5:1 for max compression on street gas (dish pistons if necessary)
4. Larger valves
5. Cams
Outside the engine I will do:
1. Underdrive pulleys
2. 80mm Ford MAF
3. LPM chip
4. Custom cat-back exhaust (single)
5. K&N snorkel
6. BB Butterflies
Did I mention this is going in a '95 Windstar?
Anyway, I need some specs for my DCR calulator. Does anyone know where I can get really thorough internal engine measurements? For instance:
1. Combustion chamber displacement (3.2)
2. Factory con-rod length
3. SHOshop cam specs (stage 1)
4. Head gasket thickness/bore
Thanks for your help! My Windstar will keep the bone-stock look... hope to surprise you on the street someday!
PS - I'll be removing the back seats and spare tire, and replacing the carpet with a rubber mat. This should put my weight real close to a factory SHO.
4. Larger valves
5. Cams
2. 80mm Ford MAF
3. LPM chip
5. K&N snorkel
6. BB Butterflies
