If you are trying to move a Windstar, increasing DCR is probably not the right direction, unless you are going to significantly decrease weight. Also the tune for a high DCR engine is less fault tolerant.
To bound you, most that have gone beyond 10.5:1 static on these engines, even with the longest duration cams currently avialable (SHOnut +40's or SHOshop Stage 2) have not been able to run pump gas. Not sure how many have payed attention to quench distances and those sorts of things.
IIRC, the 3.0 SHO was either .007 above, or .007 below on piston to deck, sorry I can not remember which direction.
As to strokers, the welded up and reground journal/reuse stock rod approach used by the SHOshop did not work well, possibly because most ran with a type of crank underdrive pulley that had no rubber (or any other sort of) dampener to them (crank vibrations can be bad for fatigue). Those that have gone to the Honda 48 mm rod journal diameter, so far so good but no high rpm work yet.
Much of the Performance sections of this site recently got scrambled, the owners are still trying to unscramble, until then mining for the types of data you'll be looking for will be difficult.
Hope ths helps - zak
