Orlando area? PLEASE HELP
WTFvolvo
Broken sho
Kissimmee, Florida
Car has been sitting a while because it out of the blue broke down on me.
I pulled out of a parking lot, and casually started going, then the car just stalled out, no noises, nothing. It just stalled. When I tried to start it, it would only turn over, but would not burb or stutter or show any signs of it wanting to start. It isn't getting spark, not sure about fuel.
Is there anyone in the Universal Orlando area that can maybe help me get it started?
I am about to go to kissimmee to pick up a new relay module... thing above the radiator.
I NEED this car to work. Very important that I have a running car.
PLEASE HELP!!:thankyou:
WTFvolvo
Broken sho
Kissimmee, Florida
I know how to pull codes. I had OBDI in my volvo.
Cant really do anything right now... my battery is dead as a doorknob.
You dont have any idea what it could be? Common SHO problem?
Cocoa,Florida
hrmm could be a few things crank sensor or DIS would be my number one guess.
also make sure your ground strap on the rear passanger side of the intake manifold is tight and free of corrosion.
spark control on these cars comes from a few things.
DIS,cam sensor,crank sensor,EEC IV module,coil pack,plugs,plug wires.
the realy module you speak of has nothing to do with spark output.
WTFvolvo
Broken sho
Kissimmee, Florida
Expencive? Hard to replace?
My ECU has external damage, and that relay module that Im about to replace, is practically falling apart.
mclarida
Orlando, Fl.
Check the plug going into the side of your coil-sometimes the clip breaks and it tends to wiggle out. Easy fix but it may be a dis-
I live in Apopka...tell me where you are>
M
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
Replace the control module you are talking about. If still no spark, PM me and I will take you through testing all wires and sensors exactly. I know this harness and sensors like the back of my hand now.
hypnotic
Palm Bay, FL
HAHAHAHAHAHHAHAHAHA!!!!!
Guess whos car this used to be? Guess what it needs? If you haven't gotten it already I told you to get a whole new wiring harness. Everyone already knows about this devil car!
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
Yes, first go with a new harness if you have not already...they part out tons of cars here...get the entire underhood engine harness, CCRM, and ECU.
