Kunckle
zblackbeast
SHOtarded
Omaha, NE
Ok, the sho needs a new knuckle. The lower caliper bolt on the passenger just spins. So my question to you is as follows:
Can i use any Taurus from 92-95 or do i need to buy this thing new because it doesn't look like any parts store carries this part.
Couple ppl from Lincoln say i can, i just want to double check before i spend a day at the local yard....
ManySHOs
South Jersey
87-95 Tauri
89-93 SHO
87-95 Sable
I think...
This is incorrect.
If you have a 93, look for a 90-93 spindle with the ABS sensor attached. If you want to do a 96 upgrade (or even a 94-95 upgrade and save the 96 for later), look for 94-95 spindles and front brakes.
However, I don't understand your problem. The bolt is going to spin unless you hold it with a wrench on the other side while torquing or untorquing the nut.
Ian
NWGRN94MTX
Vancouver, WA U.S.A.
This is incorrect.
Ian
This is the correct information.
The key is the ABS sensor.
It can come on another SHO, a Taurus or Sable that had the rear disk and ABS option. I think there was a one or two years a Lincoln would work.
If you are thinking of doing any brake upgrades in the future, this is the time to install 94-95 Knuckles with brakes.
WSC-SHO
SHO Groupie
Nebraska
Naw, we had a bitch of a time getting that in too....But we stripped the bottom hole that holds the caliper to the knuckle.
Thanks for the info guys :thumb:
zblackbeast
SHOtarded
Omaha, NE
Instead of removing the knuckle is there a way to get that bolt to stay in place. like tap a new thread or take it to a brake shop and have then fix it!! :)
zblackbeast
SHOtarded
Omaha, NE
Ha, sorry, that was tim who posted that...
IDK. i got a PM from someone who will sell me the 96 brake upgrade kit.
HA yea. good luck with that.
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
I'd heli-coil it, its not very hard at all. If you can use a drill and a tap set, you can do it. I have to do it all the time at work on Dodge products IE: Dakota, Caravan, etc
- James
zblackbeast
SHOtarded
Omaha, NE
ok sweet. can i pick up a heli-coil at any parts store?? how does i go about threading in.:wave:. just like a normal bolt.
zblackbeast
SHOtarded
Omaha, NE
Ok. so after i watched a few vids this is what i came up with.
Drill teh hole to make it bigger, tap the hole so the heli-coil threads in, thread heli coil in, break off end piece, thread bolt in...
Can, should i use this on the shifter stabilizer instead of just taping it.. I bought a 12 x 1.5 mill tap today 4 it.. matches up with the hole well.. didnt thread it in yet tho..
pjtoledo
'ol man in the SHO
toledo,ohio,usa
on the 10" front brakes there isn't much extra metal around that hole, I would pass on the heli-coil and get a good used knuckle. as stated, now would be a good time for a 96 upgrade
