Whats behind the DOHC side badges?
Phoenix
SHOHOLIC
QC , Canada
Holes? , is the glue easily removable?
What product you used to remove the glue?
I got the heat gun ready :naughty:
keny_kimmel
ETSN Kimmel(SS)
puyallup, wa
Use the waxy-plastic style dental floss. Thin fishing line is the best if you have it.
Heat the badge and then start from a side and slide the floss under it, almost using a sawing motion and gently pulling towards you. And it should just pop right off. You might have to occasionally reheat the badge.
keny_kimmel
ETSN Kimmel(SS)
puyallup, wa
The dental floss trick is easy with the heat-gun or hair drier. 98% of people above the Mason-Dixon line have floss.
NCTaurusSHO
Guest
Elizabeth City, NC
you can also use the fishing line/floss technique to slice a cake into layers. just for the record. lol.
ashley
