help abs and srs light on
Endri_SHO
SE 300 , S 500
IN THE MERCEDES-WORLD
hello,
just bught this 95 mtx SHO couple days ago ,
1-. recently the srs airbag light is flashing 4+2 and than again 4+2 and on and on same numbers,
2-. also before i bought the car from the previous owner the rear brake lines were broken and all brake fluid had leaked out , i think ( but not sure) the master cylinder reservoir was dried out completely , so anyway i took the car at the mechanic today and had the rear brake lines replaced with new ones. The brake pedal got good presure now but the ABS light is on , is it beacuse air got in the system and all the calipers need to be bleeded?? cause the mechanic only bled the rear brakes , i told him to do the front ones he said no cause i am not replacing a master cylinder , i was like what the **** :ohreally:
anyone could help me with this isues??
thanks
Racer X
SHO Pilot, Retired
Connecticut
you can scan ABS codes just as you do EEC-IV codes. Do a search, there's a guide somewhere.
Endri_SHO
SE 300 , S 500
got the abs info on how to rund the codes.. how about the srs airbag code now ? what might that be code 42 and how can I fix or reset that??
Mr Anonymous
Tire Wall
St. Louis, MO
Airbag code 42 is "Center Radiator Primary Crash Sensor Feed/Return Open"
Sounds like it's a bad sensor or damaged/disconnected wiring.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Taken from Here Thank SHOZ123
ABS codes from the '93 Helm.
DIAGNOSTIC TROUBLE (COMPONENT)
11 (ABS Module
17 (Reference Voltage Problem
22 (LH Front Inlet Valve
23 (LH Front Outlet Valve
24 (RH Front Inlet Valve
25 (RH Front Outlet Valve
26 (RH Rear Inlet Valve
27 (RH Rear Outlet Valve
28 (LH Rear Inlet Valve
29 (LH Rear Outlet Valve
31 (LH Front Sensor
32 (RH Front Sensor
33 (RH Rear Sensor
34 (LH Rear Sensor
35 (LH Front Sensor
36 (RH Front Sensor
37 (RH Rear Sensor
38 (LH Rear Sensor
41 (LH Front Sensor
42 (RH Front Sensor
43 (RH Rear Sensor
44 (LH Rear Sensor
51 (LH Front Outlet Valve
52 (RH Front Outlet Valve
53 (RH Rear Outlet Valve
54 (LH Rear Outlet Valve
55 (LH Front Sensor
56 (RH Front Sensor
57 (RH Rear Sensor
58 (LH Rear Sensor
61 (FLS Circuits
62 (Travel Switch
63 (Pump Motor Speed Sensor
64 (Pump Motor Pressure
67 (Pump Motor Relay
71 (LH Front Sensor
72 (RH Front Sensor
73 (RH Rear Sensor
74 (LH Rear Sensor
75 (LH Front Sensor
76 (RH Front Sensor
77 (RH Rear Sensor
78 (LH Rear Sensor
And from Here
AIR BAG DIAGNOSTIC MONITOR DIAGNOSTIC TROUBLE CODE PRIORITY TABLE
Priority Code Component/Fault Description
Highest no Air Bag Indicator
Inoperative Lamp Circuit or No Ignition voltage to Diagnostic Monitor Continuous Air Bag Indicator Diagnostic Monitor Disconnected or inoperative
12 Low Battery Voltage
13 Air Bag Circuit Short to Ground
14 Primary Crash Sensor Circuit Short to Ground
21 Safing Sensor Not Mounted to Vehicle Properly
22 Safing Sensor Output Shorted to Battery Voltage
23 Safing Sensor Circuit Input Feed/Return circuit open
24 Safing Sensor Output Feed/Return Circuit Open
32 Driver Side Air Bag High Resistance or Open
33 Passenger Side Air Bag High Resistance or Open
34 Driver Side Air Bag Circuit Low Resistance or Shorted
35 Passenger Side Air Bag Low Resistance or Shorted
41 Center Cowl Primary Crash Sensor Feed/Return Open
42 Center Radiator Primary Crash Sensor Feed/Return Open
44 Center Cowl Primary Crash Sensor Not Mounted to vehicle properly
45 Center Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
51 Diagnostic Monitor Internal Thermal Fuse Blown Due to Intermittent Short to Ground
52 Back-Up Power Supply Voltage Boost Fault
53 Primary Crash Sensor CircuitsÄResistance to Ground or Internal Diagnostic Monitor Fault
Lowest Rapid Continuous Flashing of Air Bag Indicator All Primary Crash Sensors Disconnected
Endri_SHO
SE 300 , S 500
ok guys thanks for all the info on test codes , so what can i do to reset or check the wiring on that sensor for the srs?? do i need to disconect any battery before i play with airbag sensors?? and where excatly is it located??
thanks again
smokin joe
Milwaukee WI
Yes disconect the battery!!! and my 95 has had the same airbag code since i got it, replaced the sensors with no luck so let me know if you figure it out
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
The one for your code is the one in the middle of the car. Above the radiator, square looking thing, 4 screws. Check that connector... sounds like it got disconnected or something, just like Anon said. :)
shobroooo
