Help.....weird battery problem
SHOALL
London,Ontario
OK here is go's, bear with me if it seems like I am rambling........
I started having this problem in the spring........sometime it would be dead if I left it over the weekend untouched, then sometimes by the afternoon after work.....checked the battery...fine, checked the charging system....fine, checked for draw on the system....nothing. So I did notice that when the car is sitting and I attached a volt meter to the battery to check it out over a few hours it would continue to climb voltage wise until it would peak out at around 16V the drop off gradually........not always but sometimes. I replaced the battery and had no rpolems for a couple of months.........now it is back. totally unpredictable and not all the time. while running the volt gauge reads between 13.6 to 14V. Anyone have any clues....I am going to start checking gounds out now.....I have also swapped out the GEM module.
Last week I also noticed that while parked with the DRL's off with the ebrake and lights off that when my fans kick on so do my high beams......they turn off with the fans as well........you only notice this if the DRL's are off and the headlights........HELP
Steve Dionne
Methuen, Ma.
I had a very similar problem about a year ago and found that the alternator housing was cracked. Replaced alternator, haven't had any problems since.
I would disconnect the DRL module for now and see if the problem goes away. It is made by Lucas of England......
NebraskaSHO
Harumph!
Omaha
Interesting to see if it is the DRL for those with that on their cars.
Mine included.
66goat
stafford sp, ct
Always remember Before taking on a repair of any lucas equipment. Check the position of the stars,**** a chicken and walk three times sunwise around your car chanting:"Oh mighty prince of darkness please spare your unworthy servant"
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
You said you checked for draw on the system. I'm assuming you put a meter between the ground post, and its corresponding wire? I know how battery problems go, I got a leaky cell in one, so my trucks battery is now in the car. :)
stephen newberg
Ladysmith, BC, Canada
You got that right. Ah, the Brit sports cars and Trumph 650s of my youth... :cool:
pax, smn
tqmx1
sacramento ca.
Now if you want to here somthing that will make your hair stand up on end. The Mercedes-Benz there ABS is Lucas
Just gives you the warm fuzzies:nut::rofl:
SHOALL
London,Ontario
lights
I am going to disconnect the DRL box tonight and try that......Thanks for all the inout......:thumb:
You will lose the high beam indicator when you do this. You can jumper a couple of the connectors or get a DRL delete plug from any Taurus/Sable that does not have the DRLs.
SHOALL
London,Ontario
lights
Anyone know what wires I need to jump to get this to work...........All taurus and sables in Canada have DRL's so the jumper plug will be super hard to find........
Funmart6
my name is mud
Auburn, Alabama
I remember my Triumph TR-6 had Lucas everywhere of course, the horn was called a "clear ******" ha, ha, (true story), One day I turned on my flasher (hazard) lights and smoke started coming from the dash so I immediately turned them off and never turned them on again.
Here's the DRL plug. It would be easier to pull the fuse assuming the DRL module isn't shorted. Otherwise jumper pin 1 & 8.
Drl module c186 g3
tqmx1
sacramento ca.
Radio
Well I found the draw on mine, :woohoo:The radio unit in the trunk. Was about to change the Alt. but disconnected it and the draw stayed the same ( the oll 189k alt is still going strong!) started pulling fuses and plugs finley ended up in the trunk disconnected the RCU and the load dropped to nothing.:)
My car had the radio foot ball drawing too much off line power. Bought a used one and it was just as bad. Third time was the charm.
SHOALL
London,Ontario
batt
So far so good.........but its only been a few days.........mine is weird because it is not all the time and all my stock radio stuff is out..... I am running my custon EATC unit....
SHOALL
London,Ontario
OK did the DRL disconnect.........still doing it........disconnected the Altenator.....still dead.......rechecking for drains now I guess......
tqmx1
sacramento ca.
It sounds like the spark chasing is about ot start:dribble: Good luck. I hope it's the first fuse you pull.
SHOALL
London,Ontario
problem
Hey....checked everything out today......put the light on between the batt cable and batt.....light is on......pulled every fuse inside nothing changed.....pull on under hood fuses......light still stays on except when I pull the dist blk fuse. They only thing I could not get to is the small plug on the altenator to see if it is drawing power.....the light is not on full either and has a slight pulse to it.......think its the altenator?
