Installing Plug Wires
ultimatesho
Fort Bragg, NC
ive heard of a couple changing them without romoving it........or atleast they claim to have............
me personally i dont c how it could b possible.........just MHO tho......
Kilty423
Sho-fer
Pennsylvania
It can be done..i have done it. I fortunately have skinny wrist lol so it was easier...there is just enough space for the ratchet to fit on both sides..well at least for the mtx..not sure about the space issue with the atx...
5SpdSHO
soldthesho
SCS, MI
I've done it without taking the intake off and it is not a fun job. I suggest taking it off.
snm95ls
KC
Been there and done it just recently. It sucks, but it can be done.
I ended up taking off the intake to check out some other problems though. While it was off, I re routed them so that they were nice and neat.
I've done it w/o taking off the intake too, but its about the same amount of work either way...
bryantaylor
SHOme yur bewbs
jacksonville, fl
it can be done without taking off the intake, but it down right sucks! the intake just takes a few minutes to take off anyway. and while its off why not clean and port it? thats what i am doing today, lol
SHOrus
For SHO
Two Harbors (Duluth), MN
Yeah, I'll just take the intake off then. Is it a pretty straight-forward task, taking it off?
Another question also. Do any of you guys use any kind of sealer when you put the intake back on or rock gaskets only?
AREA 91
Area 91
It's a catch 22 situation. It's easier to do the wires with the intake off, but you have a better chance of getting an intake leak when removing and installing the damn thing.;)
AREA 91
Area 91
You can re-use the intake to head gaskets if they arein good shape. DO NOT USE RTV!!!!!:thumb:
RiceeatingSHO
Travis R
Alabama
I did mine with the intake on. But it wasn't very fun. I did most of it at night too...lol
muzik
MN
I've done 5 sets (2 ATX, 3 MTX) without taking the intake off and didn't think it was that bad. I have never wanted to remove the intake without a good reason I guess. 1st set took about an 1 1/2 but can do it now in about 1/2 hour. It is easier if you remove the clips from the coil end and reinstall them when you are done then they fit right through.
RiceeatingSHO
Travis R
Alabama
ok, I see what your talking about. I just routed mine after plugging them in to the pack.
SHOrus
For SHO
Well, I got'r done today. Car runs like a dream now.
On another note, there is no reason the intake should ever have to come off to change plugs and wires, you just need study where stuff is at and take the few things off the back of the intake that are there and bam, plugs and wires with the intake on, no problem, and I'm a noob at this. For those wondering, I was able to run them in the exact same routing too.
