Car Won't Move In Any Gear!
Best Sho
Hudson Falls, NY
Hi, my 94 Sho 5 speed barely moves forward in 1st or backwards in Reverse.
The engine revs very high and it will move slowly, very slow. Not drivable!
So I am guessing tranny, clutch, clutch cable or tranny fluid.
Can someone help me or tell me how to determine what it is for sure??
Thank You All!
Happy and Safe Holidays
SHOspazz92
Banned
Triad Area, North Carolina.
Thank You All!
How old is the clutch?
-Sam
Best Sho
Hudson Falls, NY
Don't know, but hand a factory service work done, about 3 years before I bought it. I got it with just barely 56 k on it. My wife been driving it as I been sick alot last year and teh gears have been grinded.
It now has 96 k on. It been acting up lately, so I figure it got to be one those to do with tranny.
I actually don't know if tranny work was done it, but she was in mint condition when I got her 3 years ago.
Best Sho
Hudson Falls, NY
I should also add
That the clutch cable is stretched, but would that cause this problem>
I can't smell if anything burnt, because I have a clogged and stuffy nose. That time of the year.
SHOspazz92
Banned
It may be time to replace the clutch cable then. Perhaps the cable is binding and not letting the clutch fully disengage. I thought I had the same thing recently happen to my car... Unfortunently my clutch just let go out of no where. Hope this is not that case.
-Sam
AREA 91
Area 91
I hate to say it, but I believe it's time for a clutch.
I would start by checking the cable, fork, and quadrant first though. Keep us informed.:thumb:
Storm-Chaser
Shit Louis
If the clutch is working correctly, neither transmission fluid nor the transmission itself would allow it to slip like it would in an automatic transmission. If the fluid were low, it would drive (pull) normally for the most part until the lack of fluid result in bearing failure or seizure of internal components (read a few threads on blown differential-pins). And unlike the ATX, the MTX is direct drive - there are no internal clutches inside the case which can slip. Only the clutch or components which actuate the clutch [quadrant, cable, lever, bushings] would result in slipping, as described. So in the absence of internal noise from the transmission, it's most likely the clutch or clutch components.
One added check, would be to try and accelerate in second gear from a full-stop. If the clutch is slipping as badly as described, you won't be able to get the car to move. But a word of caution - if the clutch disc is the problem, you will like create additional damage if you keep trying to drive the car, as at some point the rivets in the clutch disc material will begin to eat into the flywheel surface.
Other things you can try, is to remove the clutch cable and first check for binding or excess play in the clutch lever and cable. Second swap the cable to see if it makes a difference.
There are a number of threads on clutch problems, which will include information (symptoms, fixes) that may help you here. Some simple things you can do, is to get someone else to fully depress the clutch pedal and measure the amount of forward-to-aft travel in the clutch lever.
Thank You All!
