brakes on 95 SHO ??
01SVTSnakebite
Massachusetts
ok, i got this car not too long ago, Its a 95 MTX, and well...Whenever i slowly come to a stop, the brakes (sounds like under dash) make a ratcheting noise....then FORCES my car to stop lol talk about strange luck. well anyways, ive searched but havent found much similiar. This happened when i got it and after i put new rotors and pads on and cleaned the abs equipment. Its kinda like...the less force on the brake...the faster itll stop when it does this. and its only when i am gradually coming to a stop.... any help is GREATLY appreciated (since this IS my DD now ,lol) :thumb:
1993MTXSHO
Its a Taurus...
Jersey
sounds like the abs is screwed up or something. Maybe the module up front is bad?
EDIT: this is the thing im talking about, its near the air box
Sounds like its might be something else though to me though, did you run codes yet?
01SVTSnakebite
Massachusetts
... dont know. would that throw a "cel" ??could anything simple(if there is such a thing on a sho lol) like air bein in the brakes lines maybe do this? its so weird really
EDIT: run codes....without the MIL on ? is that possible??(im dumb to Pre ODBII cars)
Shoaz
Studly dood
Scottsdale, AZ
There's a separate 'ABS' light for when the ABS computer thinks something is wrong. It could be that the lamp for that has failed...you should see it at startup.
1993MTXSHO
Its a Taurus...
Jersey
Its youre power brake booster just did some research for you. That is my FINAL ANSWER go change it:cool:
1993MTXSHO
Its a Taurus...
Jersey
it is??? lol hows that work? valves and Stuff in there? (or diaphrams,w/e lol)
the return spring dies.
EDIT: here this might explain it better, this is direct from the 2003 SHOSHOP catalog:cool:
Sho-N-Go
Indiana
I am inclined to say it is not your booster save your money. What is probably the case is the abs tone ring is cracked or missing. This causes false actuation of the abs system. It will not set a code or light due to the system thinking it is acting right. Look on the front axles to see if the tone rings are broken. Hope this helps
SHOMON
95 MTX
MEDWAY MASS.
Just run the codes for the abs. It may help you track down which wheel specifically has a bad part like the tone ring or sensor. The abs computer will tell you erratic output or no signal for each wheel.
Mr Anonymous
Tire Wall
St. Louis, MO
if your car doesn't have that light on, odds are its the booster.
http://www.shophoenixproject.com/eec/eec.htm
You're basing your diagnosis on a SHO Shop catalog? :nut:
Yeah, just get rid of any tools you own. :shakehead
The fact that they couldn't even spell LOSES properly really gives me a warm and fuzzy feeling that their automotive diagnostic skills. Not.
I've worked on over a thousand SHO's, and replaced a whopping two brake boosters. They are not a common failure point, and I'd be much more inclined to agree with Chuck that the ABS rings are the best place to start.
01SVTSnakebite, you can isolate the ABS system as the cause or not by simply disabling it (just remove the connector from the top of the computer and test drive the car). If the problem goes away, it's ABS-related, if it's not, it's elsewhere and we can help you diagnose from there.
Basic diagnostics are an amazing thing! :wave:
01SVTSnakebite
Massachusetts
ok so...you're telling me to disconnect that big clunky dangerous looking plug by my intake(kinda in front of rad. but before intake)?.... I will check for Exciter rings tomorrow(im guessing thats the rings that looks like it gets read magnetically?? and possibly on the end of cv)
Mr Anonymous
Tire Wall
St. Louis, MO
Yep, just lift the metal retaining lever and remove the connector. The ABS computer is pictured above.
Nothing dangerous about the plug, but obviously you don't want to be disabling your ABS system and test-driving the car during a snowstorm or other bad weather.
87hurricane
State College, PA
Anything wrong with disconnecting the ABS computer and leaving it that way for now? My ABS light has been on since I got my car, ABS definitely isn't working, but I don't have the time or money to fix it right now. Even though it would be nice to have ABS, I can deal without it right now, and it sure would be nice to get that annoying ABS light off on my dash.
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
what about the ABS relay?... could that cause symptoms like this?
I agree with the abs rings, but ive heard of a bad relay causing strange ABS symptoms
Mr Anonymous
Tire Wall
St. Louis, MO
There is a shorting bar in the ABS computer connector that sets the light when the connector is removed, so that will not make your light go away. You'll have to pull the bulb in the cluster, or just figure out why it's on. You can pull ABS codes the same way you pull EEC codes.
shobroooo
