New finds : dual pistons calipers and big rotors!
black92
Wisconsin
Plus Cobra capliers arnt really that expensive. Nor are the rotors, which I buy from rockauto.com Its cheaper then buying then at my local parts store and they are delivered to my house...
RStalveyARFF
too many shos
Georgetown, MA
Have you priced out cobra calipers lately? Ford bumped em up about $200! Not cool...
whiteman_01
Well-Known Member
Hastings, MN
Ok, i have the 11.6 upgrade on my 92. If i were to buy these cobra calipers, what else would i need besides the rotors?
K-Dawg
Treasure Coast, FL
You don't need new banjo bolts if you get the newer calipers with the coarse threads (same as Taurus banjo bolt threads).
zak
east of Hartford
Baer used to make a kit that used these 2 piston PBR calipers in conjunction with a vette rotor that was trimmed down to 12.5 inch diameter. They would hack the ears off then redrill 89 to 93 front hubs to bolt the caliper on.
I wonder is we could somehow do a more modern rendition of this using a cut down and redrilled Cobra brake rotor - have it still fit in slicers/other 16" wheels.
zak
LOUDSHO92
Rancho Cucamonga, CA
There are 12" using turned down 13" and using Cobra calipers....
I had a 92 and I needed to buy new Banjos. Just saying as it was hard to find them locally. The calipers do not include banjos.
SinisterSHO
Rust free
630, IL
I think the taurus banjo bolts also changed at some point in the years. When I bought mine, I got them for a brand new Taurus, but the ones that I had would not fit.
SolidState
No Mo SHO
Toronto, Ontario, Canada
maybe it has something to do with the change from 38mm bores to 40mm.
FWIW, the banjo bolts from my 91 calipers fit my Mach1 calipers fine.
There really is only one good choice for someone who doesn't want a track only set up, but wants better than 96 upgrade. Cobra/Mach1/Bullitt PBRs. And for the price of the calipers, even to knock 'em down to 11.6, it is a better choice than a 96 upgrade. It doesn't cost much more than a 96 upgrade with new calipers either.
Lcasho92
