iSpyder
Where to begin... A few months ago I took the SHO off the road to do full a 60k service. Needless to say it was one issue after another and finally after completing the upper 60K portion I had the car towed to my mechanic to do the front portion and fix a serious coolant leak (leaking where the pipe from the water pump connects to the water outlet; how that happened is another story altogether). Having the car wasn't critical to me so they worked on it whenever they had some downtime. So in the last few weeks they have finally gotten to the timing belt when they hit another problem. First they noticed that the timing was off by 5 teeth or so (I never even touched that) and when they went to bring the car to TDC they couldn't. He asked me if the car was running OK before I dropped it off. I told him what I had been working on and that the car hadn't been started in a while but was running fine up until when I started the job. They pulled the plugs to look in the cylinders but couldn't find anything causing the blockage. He said (I believe) that normally the first thing would be to check the rod bearings but since I said the car was running fine before he's hesitant to do that. He said he could pull the heads but that would be some serious labor and wasn't sure if I wanted to spend that kind of money. The car is stock and since it is a non-interference engine what are the chances this is a bent valve? Any other idea's on suggestions on what I could have him look at? Even though the car was running fine before should I have him go with his original instincts on dropping the pan checking the bearings? I'm at a loss and really don't want to spend thousands of dollars on a car that monetarily isn't worth that (emotionally, that's a different story). I'll be real upset if I spent all that time and effort in attempting the 60k service and never even get to drive the car.
Thanks guys. As always your assistance is greatly appreciated.
Erik
Erik
