oil change bothering me a bit
ffemtcurrence
Clutch
Sterling, VA
is 5-20w or 5-30w oil is suppose to be used...i got the old oil filter off, while putting on the new one the tool slipped and actually crushed some of the filter and bent it, but i should need to go get another one should i...it isnt leaking at all as of now...and i used 5-20w and put 5 qts in it then i put smoke out in it i mean is that to much oil i looked on the stick and i think its ok...its a ocd i have...i know this is stupid but u spend so much money to fix a nice car like the sho u wouldnt want to be wrong.....thanks guys:hail: :hail: :hail: :hail:
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
shouldn't be the end of the world either way... it calls for 5w-30... i use 10w-30
i would fix the filter
{edit} do you mean you have a total of 10qts?... cuz thats not good....
ilikepoultry
6th motor SHO
Pewaukee, WI
same here
i also wouldn't use a tool on these filters, they usually don't need one
hand tight with a rag to keep it dry should be good
a strap wrench is occasionally needed to take it off, but never tighten it with a tool (i saw this a lot when i worked at a dealership - the tool just makes it worse to get off later and it doesn't seal any better)
i'd definitely get a new filter, you don't know if somehow something in the inside broke and is loose in there - i've seen crazier things happen
don't use additives either - i've found them to cause more harm than good - my dad added some stuff to the LeBaron that is currently being rebuilt
and i never trust the stick - mine is JUST above the line after the 5 quart add and i add half a quart when it hits the line and i've had absolutely no problems
hawkeye18
Sorta cares
Norfolk, VA
The stick can lie. What is "good" at warm idle is "fill" at cold/off. The filter should be ok, but you STILL NEED TO CHANGE IT ASAP! If something broke off inside the filter... :oogle:
The only thing I would ever put in my oil would be Auto-RX, and only if it's already fxxxing up (blowing smoke, etc). Ever seen Wheel of Fortune? You know the "Before & After" category? Figure out "Snake Oil Additive" for me :naughty:. Yup, same thing!
Also; you're not OCD. You're psycho. If you were OCD, you'd type better! :laugh_ti:
SHO-NUF93
Zombie
Jacksonville, FL
I would NEVER use a tool to put an oil filter on. It's completely unnecessary and requires excessive effort to remove it after 3k miles...
ffemtcurrence
Clutch
Sterling, VA
thanks for all the replys guys...yea im a psycho...i cant believe this i basically ****** away what 40 bucks since i gotta drain the oil again and go buy another filter...dam.....but again thanks for the help:)
1993MTXSHO
Its a Taurus...
Jersey
why do you have to drain the oil again? That oil is fine, just take the filter off put the new one on (making sure to put some oil in the filter before you put it on) and just add more oil as needed. It should only need another qt. But definitely replace the filter. When you start the car just check oil pressure. The thinner oil may drop oil pressure slightly, but it will cool the engine better, be better for the engine on startup and flow better at higher rpm. just make sure the oil pressure goes up about 10psi per every 1k rpm. Im not sure if the sho does that stock but thats what the ideal oil should do in any car.
SC and SHO Blazer
Mr. Womp YurArs
Atlanta,Ga
Just reiterating what has already been said...filter tools are primarily for taking them OFF. The 5w30 that was first suggested for our engines was when they were still new and all seals and gaskets and surfaces were "baby bottom" fresh...I'd go heavier now. I even run 10w40 in my 190K 89 SHO in the summer here in Atlanta! As for the filter, I'd say since the oil isn't heavy enough...just start over from scratch...new filter, oil and all.
James E.
[email protected]
