use 1, and then move the tab on the fender to a slight angle to close the hood. I sold them because I put my CF hood on.. lol
That's how Kirk does for his Cincy hood. I was thinkiing if having only one leverage point will put too much stress on the hood tho.
I just went out and weighted the Cincy cowl, 26lb.![]()
How did you weight it as when I had a Cincy hood weighed, it came to 40lbs.
You know you can buy different struts that have different preset pressures... or find 1 of the 1000's of worn out oem hood struts that won't hold up the steel hood, but definitely would be up to the task of the cf. I use 2 weak struts to hold up my cincy.![]()
