Eaton M90 intake pics
SonicRiot
Handbanana!
CT
Bummer. I just found out the stock compression ratio of my engine is 10.5:1...
I guess a FI setup has been nixed for now.
Off Road SHO
Moderator
Why would you think that? That is what all the offroad guys are doing. Use a stock compression motor and add less boost. Use an intercooler of any sorts and you'll be fine. I still think a rear mount turbo would be good.
Tom
Jarrod
OK SHO - now in TX!
Midland, TX
So....? People add superchargers and turbochargers to stock LS2s every day of the week, and the stock CR for an LS2 is 10.9:1....
Geek SHO
SHO Addict
Rohnert Park, CA
I did the hole through the hood method:
The torque and throttle response was amazing, though the design is incredibly inefficient. There's a ways to go to make my setup work, including getting the motor back together. I can't work on it until August. . .
SonicRiot
Handbanana!
CT
Yes, but this isn't an LS2, it's a Ford-based V6...;)
I've recently started looking for a house or condo for purchase, so cash flow has been srangled to my projects. Also, my warranty is still in tact, so I didn't plan on doing this until it's out. This will give me more time for research anyway.
Warranty is out mid 2008. If I for some reason have some more funds available to me or haven't purchased another project, I'll look further into this.
Thanks guys.
E1
Crash Tested
Chicago area
An air-air IC is also not looking great. I'd have to go with an air-water IC. Anyone have any info or guidance on this?
I use Alcohol/Water injection. Can get as much as 120' F intercooling effect. Nice shot in the behind when the pump kicks on too. I go through about 1/2 gallon of Methanol/Water mix every 500 miles or so. Only kicks on around 5 PSI and above. Below 5 PSI boost you don't need anything.
http://www.snowperformance.net/
SonicRiot
Handbanana!
CT
Thanks for all the advice. I'm currently trying to move out of my current residence. All dreams are on hold.:rolleyes: I've even slowed my car-board participation to stop the painful daydreaming.
kazx9r
Virginia
my M90, front mounted intercooler setup a few years back was done by removing the AC....currently working on a new project, I have pics if you haven't already, check out
"Someone run out to there SHO for some engine dimensions"
I have pics of my setup, kinda
putting it where the airbox is seems like a good location
shobroooo
