NCTaurusSHO
Guest
soooo. I originally had an 80mm mass air on my car and 50lb injectors, I just recently put on a 85mm until i can get a 90mm. now i am having idle problems and it cuts off when the clutch is pushed in. it ran and idled fine with the 80 (but sputtered a bit under load) I used the .MAF file for the 85 mm mass air (02GT) and it runs great under boost, but bucks a little when you are cruising at 60 in 4th and 5th gear. any suggestions? And yes i am getting it professionally tuned on the dyno saturday, but i would like to enjoy my car because i have to drive it every day. thanks for any help.
here is the list of mods
GT42 turbo
50lb bosch injectors
255lph fuel pump
adjustable fuel pressure regulator
stage II cams
p/p head w/ oversized valves
honed/extruded intake runners
85mm mass air meter from an 02 GT
tweecer RT
stage 4 clutchmasters racing clutch
ashley
GT42 turbo
255lph fuel pump
stage II cams
tweecer RT
ashley
