Head work
Devin
3.Slow
Pacific Northwest
Edit, the origin heads here are junk and probably will be trashed. I got a used head set and will be swapping them in 7/11/26. Pics start here
Are there any good writeups on doing heads? I have a spare set from my original engine that need some love. I know there are guides on doing the valve lash, but what about honest to goodness teardown/rebuilds?
Devin
3.Slow
Pacific Northwest
Well, good time as any too tackle this.
1000004585
Left outside a bit too long
1000004589
1000004590
1000004591
This should be fun!
Devin
3.Slow
Pacific Northwest
haha, yup. Sometimes I forget I make them, and then find them again when searching for the same thing.
I think the heads are in about the same condition as they were back then. Just kroil'd the crap out of them. Probably let them soak for a while, as I look up rebuilding videos and walkthroughs.
Joe_SHO
ND
Man those heads are junk. There is too much metal gone to ever meet clearances.
toledogt
Ohio
Do those cams have serial numbers? Are you trying to keep the car original?
Devin
3.Slow
Pacific Northwest
I need to take a closer look at the cams, but they may be okay. The valves are rusted in their current positions though, which could be a problem.
shaldaya
Utah
Looks like you need about 5 gallons of rust remover, 4 drums of elbow grease, 3 miracles, 2 new heads, and a someone else to do the job for you XD
Gooood luck XD
Devin
3.Slow
Pacific Northwest
I assume there are no inserts to step down a thread size on the spark plug well, I'll just have to use a larger spark plug in that side?
