Drive Belt Replacement Help - Gen 1 MTX
scotc1t
Colorado
Hi, trying to replace the drive belts on my Gen 1 MTX. Alternator belt is easy enough, but I don't see how to access the adjusting screw to do the power steering belt. It seems like there are possibly two options: 1. Removing engine mount/damper that is directly in the way or 2. Jacking up car and accessing via passenger fender well. Any advice would be greatly appreciated. I am not well versed on working on the engine on this car as I am used to older V8's where belt work is much easier. Thank you very much in advance.
1990 White MTX 105K miles - All stock except SHO Shop underdrive pulley kit and Thunderbird 5 spoke wheels.
zoomlater
Seattle, WA
Shosource made a tool that allows you to get to the adjusting hex bolt on the tensioner. it should give you an idea how many extensions you might need to get to the tensioner.
scotc1t
Colorado
Awesome. Thank you very much for the tip!
BaySHO Performance
SF South Bay
Remove the end tank with the DIS and unbolt the power steering reservoir and swing it out of the way behind the intake. I use a bungee cord around the far hood strut to keep it out of the way. Then buy one of these:
or use a 5mm socket on a couple of long 1/4" extension bars.
scotc1t
Colorado
Thanks Nick! I really appreciate the options. Does anyone know if I will need different belts than stock size since I have the SHO Shop underdrive pulley kit?
BaySHO Performance
SF South Bay
You will need longer belts. I purchased these for a client in 2019. Can't for the life of me figure out where I got them from. It may have been SHO Source. They have 6 rib UDP belts, but not 4 rib.
Such a complete blank on a search for them that I am not sure now that the PNs are correct. No mention of belt PN in the SHO Shop catalog:
4 rib UDP Accessory Belt (Gates) K020553
6 rib UDP Accessory Belt (Gates) K000616
The part number gives pointers to the belt length. For instance, for a car with stock pulleys:
4 Rib Accessory Belt (Dayco) 5040500, 50.0"
6 Rib Accessory Belt (Dayco) 5060450, 45.0"
That works for the Daycos, but doesn't seem right for the Gates. The 4 rib belt would be 55.3" vs stock 50.0" and the 6 rib 61.6" vs stock 45.0". Those seem way too long.
