CCRM or PCM?
Lonely SHO
Ohio
Hello all, I've got an '89 SHO and the radiator fan has been staying on after the key has been switched to off and draining the battery. I'm not sure it this is because I have a bad PCM temp sensor or a relay in the CCRM stuck on. I would like to avoid buying a PCM and CCRM, and if possible could someone send me the pinout for the CCRM and the PCM as I have been unable to find either. Thanks for anything.
SHOrod
Torrie Tuned
Cedar Rapids, IA
Below is the diagram for the Integrated Relay Control Module (IRCM) for the 1989 SHO. Note that the EDF Relay is the relay for the cooling fan. It appears to be triggered by PCM Pin 55 at IRCM terminal 14 via an NPN transistor. So that could be a 5VDC signal from the PCM to trigger the relay.
-Rod
1989SHO IRCM
thegreatbriguy
Carlisle
Nicks right, wack it and see if it unsticks. If you need one message me I have M codes. I'm notascam.
Lonely SHO
Ohio
Thank you all for the suggestions, I'll give it a few whacks and see if it unsticks.
