Need your advice on Waste Gate issues...Turbo replacement?
Cheesehead
Schofield, WI
Well I knew this day would come eventually. Car is at the shop doing a full fluid replacement and the tech had the front right wheel off and noticed an issue with the turbo/waste gate. He said that the right-side assembly arm was hanging and that I need to replace the turbo. Does this sound familiar? Also, should I just go ahead and have both turbos replaced? Just turned 116K. Want to get some feedback before I tell them to go ahead with the work. Thanks!
Cheesehead
Schofield, WI
Also, there is no check engine light on and car seemed to drive just fine so I don't get it. I haven't been beating the car but do drive fast so I was kind of surprised when it said the assembly arm was hanging and the waste gate was moving freely
Texas Marauder
Lone Star State
It depends. If the E-clip came off (red arrow), just reattach the linkage and replace the E-clip. Most likely. If the wastegate arm broke off (blue arrow), replace the turbo. Most unlikely. Make sure the wastegate arm moves freely. If not replace the turbo.
1756841278522
Cheesehead
Schofield, WI
Awesome thank you. I have used this shop forever and trust them, but I will definitely verify!
Beat me too it! Good stuff.
Cheesehead
Schofield, WI
It was definitely the blue arrow which sucks. I'm surprised more wasn't damaged because looking back, I don't remember hearing the huge woosh of excess pressure under the hood as I have mine vented to the atmosphere for at least a week or so! It will nice to have some ponies back
SHO-moco
ct
I am very surprised no CEL came up for that. I get boost problem codes pretty quick if they arise.
SHO-moco
ct
I have a tune from Ortiz. Would that negate any dummy lights from coming up?
I do not believe so, I have a GH tune and still get check engine light and codes when things pop up. I think the only thing anyone mentions wanting or wishing to have "tuned out" from setting a light would be the down stream o2 sensors. I know thats getting harder to have happen with the stricter rules on tuning for street use.
