Service Advanctrac
Boochy47
Michigan
Map sensor omg do I gotta re tune because of this if so it’s gonna be a headache
SnuffyTheSeal
Florida
I would check your MAP sensor and the wiring to it first. You're throwing three different MAP codes and an underboost code which is partially determined by your MAP sensor. If you replace it with the same Motorcraft 3-bar sensor then you should not have to retune the vehicle. If you put the stock sensor on you will have to retune.
Boochy47
Michigan
So I can just order new one from gearhead? N plug n play
Boochy47
Michigan
Should I take off ground on battery when taking off old map sensor and putting new one on ?
shobroooo
