97 SHO still runs
Rpmmillwright
Hello all,
Not seeing a lot here for my generation. 1997 first year with the v8 cams welded. My daughter wants it. But it has a bad strut. Considering rebuilding the strut my self. I have done similar work. May have to make a few pcs. Like strut piston. Drain it cut it open rebuild reweld and repressurize. What do you think?
TankII
Bolton, CT
I have a set of fronts I can give you. A friend stripped a '96 and gave me the front subframe for my '91. So I have a set of stock fronts complete with springs and mounts. I live in Connecticut.
I daily drive a cam welded 97. Makes those times when I drive my manual cars all the more fun.
Doing what you are suggesting seems like a lot of work when you can pick up replacement struts pretty cheaply.
-Chad
Damn you Chad. I need that in my life. She is beautiful.
toledogt
Ohio
My 1996 SHO is my daily driver. I do like that custom hood picture above.
