This got quite long winded, but I believe it is worth a good read.
I have been watching a lot of the this guy.......
As a Certified Lubrication Specialist with over 20 years experience, The Motor Oil Geek channel delivers real data about motor oils from an expert perspective instead of speculation. Twice each month I will upload a new video that either analyzes a new oil, dyno tests an oil, reveals the details...
www.youtube.com
His dad is Nascar Driver Lake Speed. He is Lake Speed Jr. He worked in the engine department and developed oils for Joe Gibbs Racing. He works for Total Seal Piston Rings....so he knows his shit and backs all of his shit with science.
He has a lot of cool information about oil ect. What really got me was his explanation about fuel saturation in the oil in Boosted/DI motors. If the fuel injectors aren't pulsing correctly or efficiently they essentials adding fuel to the oil. The unburnt or dribbled fuel goes past the rings and straight into the oil. Getting a oil diagnostic can be a huge benefit in detecting exactly something like this. If you are seeing high amounts of saturation, you could be seeing the start of something bigger. Either pump failure, injector failure, inefficient injector spray ect.
I bought one of his kits and had the oil tested in the AMG. It came back okay for 5000 miles. He said things look okay but to start changing my oil every 4000 miles. I don't agree, I am staunch 3000 mile changer regardless of what it is. It seems that the Mobil 1 0W-40 Euro Car Formula isn't the best oil for my application because the viscosity break down and high calcium. Viscosity break down is normal, but not at the rate this oil should have across the board. The high calcium is a detergent that lends a big hand in LSPI. He actually has a video just about this particular oil. I had changed the oil in the AMG 200 miles ago with M1 0W-40 Euro Car Formula and after looking on the MB forums and seeing what MB says. After that video and seeing the break down on the analysis, I switched over to Liquid Moly 5W-40. Yes I dropped the 200 mile freshly changed oil. I might throw it in the VW Jetta however. When I get to 3000 miles I will change the Liquid Moly. However I am super interested in the Castrol Edge 5W-40 Euro Formula as well. I had great results with the Castrol Edge in the SHO.
What Lake suggests in a nutshell:
DO NOT FOLLOW MANUFACTURERS RECOMMENDED OIL CHANGES INTERVALS. They have incentives and CAFE requirements by the EPA and FED GOVT to prolong oil changes. Less oil used ect. It is long and winded, but they get kick backs.
Max mileage for a oil change should be 5000 miles or less depending on driving conditions and habits.
ALWAYS PREFILL THE NEW OIL FILTER with fresh oil before install. He has a whole video about this. If you don't, it does cause wear during the first start up after the oil change, because there is no oil pressure. It is not a myth, so fill the new damn oil filter. If you have a filter that cannot be filled (I do) then use the no start/ignition cut start to turn over the motor for at least 10 seconds. I did this with the SHO every oil change while filling the new filter.
Every oil change throw an bottle of complete fuel system cleaner in your vehicle esp if it is direct injection. Doesn't matter what brand just as long as it has
polyether amine in it. He has seen a correlation in reduced fuel saturation in the oils tested when this is used each oil change. It helps clean the injectors and helps with spray pattern ect. I use the Chevron Complete Fuel System Cleaner.
If you buy a new car, change the oil after 500 miles. You need to get all of the crap out of that engine before "the first recommended oil change". Manufacturers do not use break in oil anymore. You would be shocked at how much crap they pulled out of his daughters brand new Toyota that had factory 0W-8 in it. He has a whole video on that as well.
A oil analysis (to track trends), oil, a filter, and bottle of injector cleaner is cheap compared to a potential motor failure.
