New to the SHO fam, now lets rip its heart out.
SHO-moco
ct
So.... IT'S ALIVE!!. Had a couple gremlins popup Friday. Plan was to have it buttoned up for the weekend so I could drive it around, put some miles on it and see how it does. Decided to charge up the A/c as I was installing the UPR catch can and it kind of blocks the a/c port. Once charged up I fire up the a/c and its working as it should until i notice the system pressure rising and the cooling fans not coming on. So wouldnt you know, the fan control module decided to quite in the 2 months this car sat on the lift :mad:. Had to order one in, which arrived the next morning. I installed it and all was right in the world. Drove it 20 miles, brought it back into the shop and up on the lift to inspect for leaks and to recheck transmission fluid. All was good so off I go... 30 miles later as I am pulling into the driveway at home I notice the smell of oil. Park and open the hood only to find the brand new front turbo oil feed line to be leaking from the factory crimp!! So some running around the state to get the replacement part, stop by the shop to get the tools I'd need, and back home to replace it in the driveway. Fortunately it was the front one! Since then about another 120 miles and all is still right and tight.
SHO-moco
ct
So here is a question for those of you following this thread. She seems to be running good, no current codes other then the cat efficiency which I expected from these basically hollowed cats. I have no reason to suspect there is a problem but I wanted to look at some of the turbo data to see if these cartridges are doing what they should be. Now keep in mind I just went with some stock cartridges as I am not looking to hotrod this car right now. That said, when looking at the calculated turbo boost data in the scanner everything is in the negatives. Kind of threw me through a loop as I have always seen boost gauges showing positive numbers. So I am not sure what to expect from normal stock operation. Can anyone tell me what kind of calculated boost figures I should see during normal driving and then with some more aggressive acceleration? At idle I see -10 ish. When getting on it some I can get it to 0 lol. I did note that the throttle position never shows as WOT through the computer. The throttle pedal position sensor acknowledges WOT but the throttle body itself is showing 75-80 when WOT.
Found this https://shoforum.com/threads/tps-and-throttle-pedal.143023/ . Basically saying that the throttle % i am seeing is about right. So I guess I can ignore that, but any input on what to expect from the "calculated turbo boost" would be appreciated.
Texas Marauder
Lone Star State
Check PIDs TCBP_DSD and TCBP. Engine off they should be atmospheric pressure @14.7 psi. TCBP_DSD is turbo boost desired and TCBP is actual turbo boost. WOT you should be able to get mid 20s pressure.
SHO-moco
ct
Ok, I will check those out thanks.
Mid 20's from a base stock setup? I thought I had read in a couple posts guys saying 12 is about what to expect from a stock setup? Or are you saying mid 20's on the MAP readings which you then subtract 14.7 from getting you back into the 12psi boost range?
SHO-moco
ct
Forgot to throw this up, back out in the world again
Texas Marauder
Lone Star State
Boost minus the static reading = boost above atmospheric pressure. Max should be @ 10-12 psi. Desired and actual should be close, maybe +- 1 psi.
SHO-moco
ct
Whelp, back to making boost again! Simple fix this time. Went looking for boost leak points, specifically was checking out the noise maker as everyone talks about getting rid of them due to them being a common leak point. While looking in that area I noticed the clamp on the intake tube was super loose and the hose itself was just sliding around on the throttle body. I was scolding myself for how I could have forgotten to tighten such an important in your face clamp only to find out that it was the clamp itself that failed. Time and age must have gotten the better of it as it would start to tighten up then pull apart from itself. Didn't have a clamp that size just laying around so I put 2 hose clamps together to make one big enough. Once I got that hose on and tight took it for another ride and we are making boost! I still need to compare those values Texas mentions to see if they are performing decently, but I have boost again.
SHO-moco
ct
Alright, so onto the next aspect of this job. So I already had to make some front pipes for this car as the original flex pipes were shot. The previous owner had already cut out the 3rd cat and resonator. So there are only the 2 mufflers in the back, flow masters I believe. One of them sounds like it has a loose baffle in it, at certain rpms and load there is a wicked rattle out of one of them. In the big picture I don't really care for this car to sound sporty, kind of takes away from the sleeper aspect of the car. So from what I have gathered from some posts is that a MagnaFlow 11386 should be put in where the original 3rd cat/ resonator was? But what about mufflers, I have read a lot of post with differing thoughts on that of course. But none of those post really are talking about trying to make their cars quiet lol. Anyone have any thoughts on what to put on for mufflers with the MagnaFlow 11386 in order to have a pretty quiet ride? And while I know someone will say "go stock then" , whelp I looked and those pieces cannot be had now a days.
My suggestion stay all magnaflow
SHO-moco
ct
Where abouts in this magnaflow 11386 getting installed on the car? Everyone seems to talk about them but not exactly where in the system they are putting them. They look pretty large and I would think would hang pretty low if put where the factory resonator was. I have yet to see a picture of an exhaust system with the 11386 installed. Also just noted that Magnaflow lists their inlet and outlet sizes and those size's are ID measurements. Everyone using the 11386 is likely running larger 2.5 inch pipes front to back. If using the stock pipes those are 2.25 inch. That being said the 11385 magnaflow would likely be the better option as it is the same thing just with 2.25 inch inside diameter inlets and outlets.
Zpak
Es Aich Oh!
The region, Indiana
Yes, most people run PPE or SW downpipes which are 2.5”. So usually after that the third cat and resonator are deleted then the magnaflow is put in their place continuing with the two and a half inch pipe.
I think it was obscene of ford to use less than 2.5” for a twin turbo exhaust set up.
SHO-moco
ct
I have too much into this car right now to spring for another $2000+ in exhaust work just to open up to the 2.5 inch. I am not disagreeing with the 2.25 being a bit restrictive. But as I said from the start I am pretty much going to run this stock as my daily driver. So $150 won the day this time, hopefully it quiets it down enough for my liking and I can stop there lol.
Please let me know how it sounds... cant wait.
Zpak
Es Aich Oh!
The region, Indiana
Yeah I get it for sure. Just illustrating the reason for the 2.5” inlet/outlet resonator you see being used.
SHO-moco
ct
So I have been driving the car regularly with a data display up watching different info. One thing that has stood out to me is my incredibly high LTFT numbers: 18 bank 1 and 29 bank 2. Those are idle numbers, no check engine light or pending codes but damn thats a lot of richening up the computer is doing. I feel like I should look for the cause even tho it is not throwing any codes. I smoke tested it and the only leak I am seeing is around the throttle body shaft so its leaking from the position sensor and the motor housing not between the intake and throttle body. Enough of a leak to cause those kinds of fuel trims? I am of the mind that any leak is no good and should likely look into changing the throttle body. Any thoughts or experience with high fuel trims?
SHO-moco
ct
So... I got a new car... Not really, but let me tell you adding that Magnaflow resonator/muffler assembly to the car makes such a big difference! I had this rattle in the exhaust that drove mad but could never find. Under there with a rubber mallet banging on things trying to replicate the rattle to no avail. Finally I told myself it must just be the resonance of the exhaust causing the sound, but I didnt fully believe it... Whelp that noise is gone now! And the droning is soooo much less, it is actually enjoyable to drive the car now! Its could be a placebo but the car just feels like its running better and I am seeing better boost numbers, not a lot but some, not sure why that is. So for me, big thumbs up to the Magnaflow 11385 (11386 for the 2.5 guys) for those that do not have the 3rd cat and factory resonator anymore and are suffering from drone.
Now I will be changing my Flowmasters bottle resonators to the magnaflow x pipe resonator. Less drone sounds like a good thing. If you can record it would be great too. Thanks for that feedback.
SHO-moco
ct
Sorry for the delay, I had only half assed the resonator install until I knew it was going to make a difference. Now that I have it properly installed I can try to get a recording, tho I do not have a before audio to compare to the after so not sure how much it will help you. I always find videos of exhaust sounds difficult to gauge off of because of the variables. In a garage vs outside, recording device, closeness to the vehicle, all play a role in the sound the viewer hears but could be vastly different in person. That said, if I can make a video where would you like it taken from? Inside the car on the highway, under acceleration from a stop, from outside the car while giving it some rpms, or at startup? Soooo many options lol.
