Need a replacement crankshaft bolt washer
myotis1134
Anchorage, Alaska
Hey guys, swapped out my CPS and noticed that my crank bolt washers were bowed in. I was previously using two grade 8 washers, I'm not sure what happened to the original. I hit up my local random-fastener shop for an extra-thick fender washer, but they didn't have one quite big enough.
Does anyone have a part number for a crank bolt/washer combo that I can get from napa, advance auto, o'reillies or autozone? ****, we even have a Graingers in town.
At this point I've spent a good 45 minutes trying to source something online.
Based on my measurements, I'm looking for a extra-thick fender washer of the following specifications:
I.D. - 9/16" (0.5625") or 14 mm
O.D. - at least 1.75" to cover damper, but I'm open to suggestion
thickness - approximately 1/8" (0.125")
Preferably grade 8, but I'll settle for 316 stainless.
Thanks in advance
Irish Pride
Irish Inside
MusicCityUSA
There isn't a washer on the crank bolt. It's one big hardened f1ange bolt. Get a correct one from SHOSource.
-Chad
Yes, I used a 1 on purpose. The site blocks out that word for some reason.
ISHOU
Centennial, CO
Look what I have that SHOSource does not - and apparently no Ford, NAPA, Autozone, Oreilly, RockAuto, eBay, or anywhere else in the world...
Fortunately, not my only backup, so I can part with it.
There is one more to be found, in a box in my garage in Colorado. Got out of the SHO game in 2017 but still have boxes of parts. WHY? smh
