UPR Dual valve catch can seating problem
BradM
It looks like you can clock (rotate) the mounting bracket on the can. Loosen the bolts and rotate it.
BradM
You can also take that spacer and mount it behind the AC line bracket to hold it out away from the can.
Call and ask to speak to Steve 561.588.6630 - what year do you have? Mine is a 14
so the top port of the can goes to the PCV on top of the oil seperator. One of the two side ports goes to the T in the line to the oil filler, the other part of the T goes to the plastic charge pipe near the cold air box. The other port goes back to a connection near the firewall but connects to the Intake. They should have one way check valves pointing away from the catch can.
i hope I made as much sense as I could.
Luhsleeper88
I can’t see the question please help
Makes complete sense I’m just having problems mounting it
There is a 30 degree connector, I highlighted the portion that goes UNDER the AC line "****"
1706559759344
Is this an add on? I think this is what I need
When Steve was shooting the video - he added a washer - you can see it under the thumb screw, the grounding wire is under the bracket, he included a lanyard - so I wouldn't drop the turn/thumbscrew. Otherwise no other parts were added or changed. Did you order the 10-14' or the 15-19' part?
Luhsleeper88
73e73c9117d8c4315551403005462450
15-19
On UPR's site it definitely looks like they "raised" the can - AND used a right angle port.
1706561852100
